I already posted the following in the 8.5 Forums, but it also affects 9.0.1 as far as I can see:
I am testing a certifier key rollover in an environment, where IDs are vaulted.
After rolling over the certifier and before rolling over the user IDs I might have to reset a user password using the ID Vault, but that does not work, because “of course” the certifier and the user certificate no longer match.
Without the user being able to logon I cannot do the rollover of his ID, so I might run into a deadlock here.
Am I missing something?
How is this supposed to work - especially, when the documentations says that rollover and ID Vault work perfectly together?
Thank you for your input. I will take it into consideration.
We found the misunderstanding:
It is the Vault administrators ID, which needs to be rolled over first. Then you can perform an ID download (no pw reset).
Could have known, but the error message was very unspecific.
