Categorized view, View HTML problem
Hi
my first question is that, i have one view that is catagorized, i want to show that view as html and implementing CSS class in it but, but it is not showing as catagorized view,
say for example like,: i m putting the following code in view column and data properites
Name
and second problem is that i have one view that is showing employee record of the application, that is html view i have put html in view same as above,
but de problem is occurring while i m taking the dbcolumn of that view the combobox is showing the data with html tages like name, etc
ya, i know that we can create two view for the same form but i want to use only one view for HTML and one for dblook up , because same view is i m showing to user,
can any one seek inside this one!!
thx in advance!!
DEV//\
Subject: Categorized view, View HTML problem
The way I do with categorized view in HTML :
first column is categorized but hidden. Next columns are used to compute html tags.
I use ‘viewname?OpenView&RestrictToCategory=whatever’ to select the category with a dropdown box or links, depends of the UI.
AD
