Categorize multi values
hi,
my requirement is to map area and product and show the same in view.
for ex.
area1 → prod1, prod2
area2 → prod2, prod3
area3 → prod1, prod3, prod4.
now in a view i need to display area in first column and product in second column but under area1 only prod1 and prod2 should be shown and under area2 only prod2 and prod3 should be shown and so on. No fixed nos. for areas and products
how to accomplish this. kindly reply back if any one have solution. Thanks in advance
Subject: categorize multi values
A bit confused, but looks like u want to use @Left(fieldname;“->”) for first column and @Right(field name;“->”) for the second column.
:slight_smile:
Subject: RE: categorize multi values
“->” this symbol is just a representation.
i tried as you said but in the view second column, under area1 all products are diaplayed instead of only prod1 and prod2.
Do u mean all the values i.e area1 → prod1, prod2area2 → prod2, prod3
are in one single document but not in different documents?
yes. everything in a single document. what will be the good suggestion whether to have single field or two field.
Well you can play with a single field. change the fiels option to,allow multiple value on first tab
New Line option in option seperate values when user enters
New Line option with display separate values with option on thire tab of field properties.
in column property
new line in multi-value separator
Show multiple values as separate entries option in second tab.
the same formula will work in this case.
i tried but the result in view is not as expected
Expexted result in view
Column1 Column2
area1
prod1
prod2
area2
prod2
prod3
area3
prod1
prod3
prod4
but the actual result shown in view is
Column1 Column2
area1
prod1
prod2
prod3
prod4
area2
prod1
prod2
prod3
prod4
area3
prod1
prod2
prod3
prod4
i tried many ways to restrict the values in second column, but everything fails. do you have any idea to bring as given in the expected result from a single document.
r u on in gmail??
For the “first column” (‘area’) property:
Check Show twistie when row is expandable on the first Tab and then select “Ascending” & “Categorized” on the second tab.
For the second column (No Label): Get it’s property box and go to the 2nd Tab: Select “Ascending” and “Show multiple values as separatre entries”. In the column formula, write @If(area= “area1”; prod1:prod2; area = “area2”; prod2 : prod3; area = “area3”; prod1:prod2:prod3; “”)
or If you have the corresponding products in a multivalue field, you can directly map it to the 2nd column.
In the view properties, goto the third tab and under “Rows”, make sure you have selected “Height” as 9 (you can also select a different number as per your situation) and Check “Shrink rows to content”.
