Hi everybody, Can the column title be user-definable? The column title will be stored in the profile document and i want to set the column title by retrieving the value in the profile document.
Can this be done?
Thxs in advance for your help
Can this be done?
Subject: Can we set column title for views by using a formula?
Unfortunately not. You can work around it if you’re building a web application, but in the client, column titles are fixed.
One way around it is to use a shared, private on first use view, and then put code in to change the column titles via script - however, your users would all need designer access for this to work - a privelige that I’m not sure would be a good idea …
Kiers
Subject: RE: Can we set column title for views by using a formula?
Thxs for your quick response.
Just a toughtHow about creating two coulumns with the same values but different titels and hide the column with the wrong titel based on a formula.
Or you could embedd the view in a form or page inside a table and you do not show the header but table cells with the titles as computed text.
cti
Subject: Possible Workaround - Can we set column title for views by using a formula?
I have a workaround for Web application with javascript enable.Perhaps, it’s too late for this topics… ![]()
But it could help someone else…
My view is embedded in a form
In my view, the title of the column are :
Col 1 : [span ID=‘id1’>]
Col 2 : [span ID=‘id2’>]
on the onLoad event of my form, I put :
var lang;
lang=fl_browseLang; // the main criteria
switch (lang)
case '1':
id1.innerText ='TxtFR'
id2.innerText ='TxtFR2'
break
case '2':
id1.innerText ='TxtEN'
id2.innerText ='TxtEN2'
break
default:
id1.innerText ='TxtDefault'
id2.innerText ='TxtDefault2'
break
Hope , it will help someone one of these days…
Cathy
