hcl-bot
1
Hello,
Prob: I want to delete a NTfolder which contains many sub folders with some files using Lotus script.
EX:- C:\Mainfolder\subfolder1\test.txt
C:\Mainfolder\subfolder1\test10.doc
C:\Mainfolder\subfolder2\test1.txt
C:\Mainfolder\subfolder3\test341.pdf
Now I want to delete the Mainfolder (As given in example) in C drive
Can any one help. Please respond
Thanks & Regards,
Ravi
hcl-bot
2
Subject: Can anyone help - deleting dir(NTfolder) using LS
Dim iTaskid As IntegeriTaskid = Shell(Environ$(“COMSPEC”) & { /C rd /s /q c:\mainfolder} ,6)
for xp and 2000 for nt4 you might need to look at deltree
hcl-bot
3
Subject: RE: Can anyone help - deleting dir(NTfolder) using LS
Thanks a lot for your responce.
Can you please tell me in detail, because I dont have any Idea on Shell script.
Please dont mind
hcl-bot
4
I posted the code, can it be more detailed than that ?
hcl-bot
5
Thanks a lot its working fine.
I mean the parameters you used.
Its ok np.
Have a nice day
