Call Store Procedure Using Java
I need to export data from Lotus Notes to DB2.(using Java Agent and Stored Procedure). I have wrote a Java agent that opens JDBC and communicate with DB2. Communication with DB2 is working. Now, I need to call stored procedure on the DB2 server. Can anyone please point me to the right direction on how to call stored procedure using java? I can’t find any documentation on this, or I might not be looking at the right place. Thanks in advance for your help or suggestions. Below is how I connect to DB2:
import lotus.domino.*;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.SQLException;
import java.sql.Statement;
import java.sql.Date;
import java.sql.ResultSet;
public class JavaAgent extends AgentBase {
public void NotesMain() {
 java.sql.Connection connection =null;
	try {
		Session session = getSession();
		AgentContext agentContext = session.getAgentContext();
		 connection = getJDBConnection("jdbc:db2://m60.mw.company.com:60023/test", "id","password") ;
		String queryStr = "SELECT ID FROM MW.PROFILE";
					Statement stmt = connection.createStatement();
					ResultSet result =stmt.executeQuery(queryStr);
					while (result.next()) {
						System.out.println(result.getString("ID"));
					stmt.close();
					returnJDBCConnection(connection);
	} catch(Exception e) {
		e.printStackTrace();
	}finally{
		try{
		 }catch(Exception jdbce){
			System.err.println("Error closing jdbc connection");
public java.sql.Connection getJDBConnection(String jdbcURL, String jdbcUser, String jdbcPassword) throws Exception {
	java.sql.Connection con = null;
		try {
			Class.forName("com.ibm.db2.jcc.DB2Driver");
			con =
				DriverManager.getConnection(
					jdbcURL,
					jdbcUser,
					jdbcPassword);
			return con;
		} catch (Exception e) {
			System.err.println("problems connecting to " + jdbcURL + ":");
			System.err.println(e.getMessage());
			if (con != null) {
				try {
					con.close();
				} catch (Exception e2) {
					e2.printStackTrace();
			return null;
		} // end catch
public void returnJDBCConnection(java.sql.Connection con)
	throws Exception {
		con.close();
Subject: Call Store Procedure Using Java
Check out CallableStatement in the java.sql package (Java 2 Platform SE v1.3.1). Basically you’re looking to set up a CallableStatement object using the procedure name and passing it any parameters that the procedure needs. Something like:
CallableStatement cstmt=connection.prepareCall(“{Procedure_Name(?, ?)}”);
cstmt.setString(1, parameter1);
cstmt.setString(2, parameter2);
ResultSet rs=cstmt.executeQuery();
Pete
