Calender Problem
All ,
Can I use some one calender entries by any way???
thanks
Regards
Mike
Subject: Calender Problem
Hello,
U mean somebody else’s Calendar?
Tom
Subject: RE: Calender Problem
yes ,
Yes you can, provided you have got the access to the person’s Calendar.
This can be set , eventhough you dont have Access to the user’s mailfile .
Goto Tools–>Preferences–>Access & Delegation and ask the user to add u in the Delegation list and user has 2 options as far as access is concerned. One is u can just read the Calendar of that user and another (which should not be practiced) is Read, edit and Write access .
HTH
Tom
Yes, you can. What do you need to do in their calendar? It’s all about access. What access will you have to their calendar? What will you need to have to do what you need? The owner of the calendar can make you a delegate of the calendar by opening their calendar and using Tools… Preferences. (Note that if you are an administrator, you may already have access to the calendar depending on how the mail file ACL was set up by your company). At this point you, in your mail file, click on the Calendar label in the upper left (this is assuming you are running 6.x or higher) and choose Open Another Person’s Calendar.
