CalendarDateTime not changing on homemade entry
I have a calendar entry that I created with some script. It shows up fine in my calendar. The problem is that when I now go into the entry in my calendar and change the date, the notesitem “CalendarDateTime” doesn’t change. The StartDate shows properly both front-end and back-end.
My guess is that due to some lacking item on my homemade calendar entry document, the call to the internal function ".setCalendarDateTime is not being called.
If you have any hint where I might look, please let me know. I will be forever grateful.
  • Matt
