I’m attempting to setup a certifier on the CA process. I go through the initial steps of migrating the certifier through the Admin client, everything seems to go fine. (I’ve waited a day since that to give all the server processes time to run.) When I go to start the CA process, I get the following error on the console: CA Process: Error initializing certifier context (O=MyCompany) from ICL db IDStorage form: Entry not found in index
When I show the stats on the CA process I get:
08:25:45 AM CA Process Status:
08:25:45 AM 1. O=MyCompany
08:25:45 AM Certifier Type: Internet
04 08:25:45 AM Active: No
08:25:45 AM Init Error: Entry not found in index
08:25:45 AM ICL DB Path: icl\icl_2051.nsf
The certifier type should be Notes, not internet. I can’t figure out how to fix this to make it work. I’ve done the exact procedure in a test environment several times, and haven’t had any problems. Is there something I Can do to fix it, or is there a clean way to get rid of all the CA process stuff for this certifier and redo it?
Thanks in advance.
