CA Process..need help
  This is still about the CA Process (For SSL). I've just followed the steps in" Securing a Domino server with SSL using the CA process. In that procedure I have created a Certification Request Database, two key ring files (.kyr for my two different servers), two stash file (.sth for my two servers) and also Ive used the Issued Certificate List (ICL) database which I have created.
 Now, this is my problem, I just want to follow the steps in "Setting up SSL using Domino as the Certificate Authority". And I want to clean / delete all the files such as the kyr and sth files I have created for my two servers previously. How can I do it? also how can I do it without affecting the two servers Im using? I do want a clean SSL setup using the second procedure. Please help me on this.. I need to figure it out as soon as possible. I will appreciate any help or assistance you may provide.
 Thank you very much
