Hi all,I have written a code for lock the document.here i am also capturing history off the person who make different change.i have a field cappture the stastus.it will work properly.my code is here…
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim history As String
Dim history1 As String
Dim answer As Integer
answer = Msgbox("Are sure, that you want to lock this document for further editing",4+32,"International Certification Library")
If answer = 6 Then
history1 = "Document has been locked by " & session.CommonUserName & " on " & Now &""
If uidoc.IsNewDoc Or uidoc.EditMode Then
history = uidoc.FieldGetText("History")
If uidoc.FieldGetText("ProjectNo") = "" Then
Msgbox "Project Numer must be entered before lock this document"
Exit Sub
If uidoc.FieldGetText("DocStatus") = "Locked" Then
Msgbox "The document was already locked"
Exit Sub
Call uidoc.FieldSetText("DocStatus","Locked")
Call uidoc.FieldAppendText("History",Chr(13) + history1)
Call uidoc.Refresh
Call uidoc.Save
Call uidoc.close
Else
If Not uidoc.EditMode Then
Set doc = uidoc.Document
doc.History = doc.History(0) + Chr(13) + history1
doc.DocStatus = "Locked"
Call doc.save(True,False)
Call uidoc.close
but when i want to unloock the doc with another button it not work.Pls advise where i make change.
my defult status is “0”.
and its code is here
answer = Msgbox("Are sure, that you want to unlock this document for further editing",4+32,"International Certification Library")
If answer =1 Then
'If uidoc.FieldGetText("ProjectNo") = "" Then
'Msgbox "Project Numer must be entered before lock this document"
'Exit Sub
'End If
Call uidoc.FieldSetText("DocStatus","0")
'Msgbox "The document was already locked"
'Exit Sub
'End If
Call uidoc.Refresh
Call uidoc.Save
Call uidoc.close
Else
doc.DocStatus = "0"
Call uidoc.close
Sorry for such long mail.
pls help me.
