Button problem in notes client
hi
i have a button called “submit” this button should be visible to 5 people based on some field value i had written ahide when like…
user:=@name([cn];@username);
@if(temp=“1” ; user=txt_name;temp=“4”;txt_name1;temp=“7”;txt_name2…)
this is not working fine it working only for one person
txt_nam1 txt_name2 are fields…
what is the soluton or code for this…
Subject: button problem in notes client.
hi reddy,
wat i think, if you take the a filed whcih is multi valued, and then asign all the values(names of person) in that field and then put the code i think it will wrk.
mins User :=@name([cn];@username); (multy value)
Subject: RE: button problem in notes client.
Dont think it will work that way…
I would rather suggest that you create a new hidden field (say “hidden”)which captures the name based on temp value with:
@if(temp=“1”;txtname1;temp=“2”;txtname2…)
And then hide your required field with hide condition @username!=@name([CN];hidden)
In the first condition (temp =1) u compare user and txt_name, but in remaining conditions u are simply putting the txt_name1,…
shouldn’t they also be user=txt_name1… user=txt)name2…
I don’t quite understand what you’re trying to do, but instead of -
shouldn’t it be -
@if(temp=“1” ; user=txt_name;temp=“4”;user=txt_name1;temp=“7”;user=txt_name2…)
of course i had written the same thing what you did
it is working only for one person dear…
check that all the names are in one consistent format.
I’ve found that the hide / when formulas seemt o have some limits when using @functions.
I know I had problems with @thisvalue.
I have no ideas if this is what you’re running into, but as a work around I put the code into a computed field to make sure it worked fine (I could see the value). I would then copy it into the hide / when - if it no longer worked… Then I guess it was a problem of an @ function not liked in the hide / when and I would just reference the computed field instead.
hi das
this is not multi value field based on two conditions i want to display to the users
like
if temp=“1”; user=txt_name1;
temp=“4”;user=txt_name2;
like this i want to display
as you said if i tak multi value field how to do this…
