UserToolbarTemplate in bookmark.ntf was modified by previous employee, they added new outline entries in the UserToolbarTemplate and this has worked fine to date. The outline entry uses @Prompt([OkCancelList]) to show user list of databases.
I now need to modify this list of databases. Simple change to the list of databases in the @Prompt([OkCancelList])formula.
I have made the change in the bookmark template. I closed notes then deleted my own bookmark.nsf, cache.ndk, desktop6.ndk and re-started notes.
But I can’t get the new list of databases to appear. I also deleted all but the first 4 lines of my notes.ini file, found this in another thread. But still not working.
(I also checked my code in the @Prompt([OkCancelList])in another database is case it was that but to joy)
When I look at the code in the .ntf it is the new code. When I look at the code in the .nsf in the UserToolbar and UserToolbarTemplate outlines both new code yet when I press the icon I still get the old list of databases.
Any ideas what I am missing?
