Body Field Not Holding Values For Some Users
Hi all,
Got a strange issue here.
A document has several body fields but the first of these called simply ‘Body’, doesn’t retain values for all users.
For example, I add a simple word into the body field, save & close and open again. Word is there.
User does same on same document and word is not retained in Body field when re-opened.
If this body field was corrupted, then I presume it would be failing for all.
Hence, I’m thinking something in user setup/pc perhaps … ?
I have deleted cache.ndk for one affected user but that has made no difference.
Has anyone out there experienced such odd behaviour . ?
And does anyone have any thoughts as to what I could try to alleviate the problem . ?
Many thanks in advance for any help.
Andy
Subject: Compact the Workspace
For this particular affected user, I just compacted the workspace and tried to attach again.
All is well now.
But then same compaction didn’t help for another user.
As a start, is there a way to compact the workspace each time Notes is launched . ?
We delete the cache.ndk file each day upon PC startup as we found the cache file getting quite large.
