I’ve been working on a problem for a long time now, and thought I’d see if anyone could offer me any suggestions.
I am appending some text to the message body
field, and right at the point in the code
where the email gets sent (this is notes code,
not mine), the message body looses the text.
In the code below I would expect szDebugHere4 to be the same as szDebugHere5, but szDebugHere5 is blank.
As a test, I added some debugging to the
Common script library, in CSDocSendPrimaryNotice. The code below is copied and pasted from COmmon, CSDocSendPrimaryNotice.
In the code below, the only code added by me is to print the message body before and after the email is sent. Before the email is sent, the
message body is correct, but afterwards, it has
lost the message body!
I’d be really grateful for any pointers if anyone has any ideas!
If (fSendOptions And 1) Then
' first, prepare the backend document for sending
Err = 0
' Morph the cal entry into a notice
Call vBEObject.PreSendPrimaryRequest()
Stop
Dim szDebugHere4 As String
szDebugHere4 = "szDebug4 " & vBEObject.document.GetItemValue("Body")(0)
Messagebox(szDebugHere4)
Stop
' invoke the (LS) callback object - mail the initial invitation
Call vCallBackObject.SendPrimaryRequest()
Dim szDebugHere5 As String
szDebugHere5 = "szDebug5 " & vBEObject.document.GetItemValue("Body")(0)
Messagebox(szDebugHere5)
' Revert doc back to appt.
Call vBEObject.PostSendPrimaryRequest(Err <> 0)
'we need to instruct the mailer not to attemplt to route the on-disk calendar entry
Call vBEObject.document.ReplaceItemValue("MailOptions","0")
Thanks,
Josie
