I have added the category filter to the view control in an xpage.
The corresponding view has a categorized column as the first column which i use for filtering.
The problem i am currently facing is that the xpage shows correctly but a blank empty column appears as the first column.
Is there a way so that i can avoid this blank column to appear in my xpage?
Regards,
Amit
