Blackberry and Traveler 8.5.1 on same box?
I have got a few requests on adding Traveler 8.5.1 to an existing Blackberry box, in a transitionphase before removing blackberry from the box. While probably not a tested or supported configuration I was wondering if anyone had tried it and if it works. Thanks for any input.
Subject: Traveler and Blackberry
Hello - Yes we have seen several customers run both on the same box. The primary concern is system resources. Lotus Traveler reqiures about 512MB free memory to run properly. Otherwise no issues are known.
Note: Some installations of BES will set HTTPDisableJVM=true in the notes.ini. Be sure to remove this parameter or set to false or Lotus Traveler will not start.
Hope this helps.
Subject: Thank you for sharing.
