I’ve been reading about LZ1 compression and decided to try it out on my mail file. So I turned this feature on yesterday afternoon on my file on one server (we are in a three server cluster).
Today at lunch, every message in my inbox disappeared. Poof! Just gone. Some other observations regarding this:
When I opened my mail file on the other servers in the cluster, the messages were still in my inbox.
Even though my inbox was empty, it was still showing that I had unread emails.
When I deleted an unread email from my all documents view that I know was in my inbox, the unread count of my inbox went down by one.
When I open my inbox in the designer and preview, i see all the documents that used to be visible.
New emails delivered to me are showing up in my inbox.
Can anyone explain what happened or how I can get these messages to show up again? I’ve tried compact/fixup to no avail.
Looks like I will scrap the idea of turning on LZ1 compression. Yikes!
Mike
Subject: Search this forum for “View Unread” or “View All”
Subject: RE: Search this forum for “View Unread” or “View All”
I understand that, but that doesn’t solve my problem.
I still can’t get the original emails back in my inbox and I don’t know why they disappeared in the first place.
Subject: Are you saying you don’t have View Unread turned on?
Subject: RE: Are you saying you don’t have View Unread turned on?
I had View All turned on. But it doesn’t matter whether I have it turned on or off. I still don’t see the messages that used to be in my inbox. Your post is unrelated to my problem.
Does the button on your tool bar display ‘View All’ or ‘View Unread’. If it says ‘View All’ click it and you should see all of the messages.
If the button displays ‘View All’ you are viewing the unread documents only. Conversely, if the button displays ‘View Unread’ you are viewing all of the messages.
I understand that!!!
The problem is every message disappeared from my inbox! It doesn’t matter if I click View all or View unread. I still don’t have the old messages.
Subject: On a different tack
If you go to view all documents, are the messages still there, but just not in the Inbox, or have they disappeared from the database?
Subject: RE: On a different tack
Thank you.
Yes, the messages are still showing up in my All Documents view. And when I delete an unread document from my All Documents view that I know was in my inbox, the unread count in my inbox goes down by one (even though that document isn’t displayed in my inbox anymore).
Subject: *If the unread count still shows documents, but none are displayed, I’d rebuild the view (Shift F9)
Subject: any luck rebuilding index with Shift-F9?
If the unsaved Designer preview shows the missing documents in the Inbox, it’s likely that they’re still associated with the folder. If Shift-F9 from the client doesn’t bring them out of hiding, try a saved preview in Notes after making a trivial change to the definition of the ($Inbox) folder.
FWIW, Alan is a good guy to have on your side. He’s an IBM insider who knows ND better than almost everyone, and he’s concerned enough to offer help. I try not to yell at him too much.
TN
Subject: RE: any luck rebuilding index with Shift-F9?
Ted, that did the trick! Thanks.
Alan - didn’t intend to get snippy. Frustrating day.
Mike
