i’m trying to resolve that problem since 2 weeks!
when i type “sh ta”, i see that smtp and
router tasks are runing, but if I do
a netstat -an | grep LISTEN on a shell
console, I have only these 3 ports listening :
httpd (80)
domino(1352)
sshd(22)
there is no smtp port listening,
I can’t receive any mail from the outside !!
please, i really need help!
Subject: Big Smtp Problem !
You might have linux process capturing smtp port prior than Domino.When you start domino, don´t you get any message showing this ?
Subject: RE: Big Smtp Problem !
no, i get no message from domino except thesesnormal messages :
06/30/2005 12:36:02 PM Agent Manager started
06/30/2005 12:36:02 PM SMTP Server: Starting…
06/30/2005 12:36:02 PM Database Server started
06/30/2005 12:36:02 PM SMTP Server: Started
i tried telnet and i can’t connect to port 25…
Check if your RH firewall is running and blocking that port.Also, if the linux user that holds domino installtion is restricted, change it to unrestricted.
good luck
i just added the expor LD_ASSUME_KERNEL=2.5.5
to the domino user’s .bahsrc
and everything seems to work now
but i’ve got an other problem,
when i launch the server from
a ssh session, as just as i quit
the ssh session, the server stop,
would you know why?
That’s an operating system behavior.To keep domino running, you can force it to keep alive after session is closed.
try this…
nohup server &
