Beginner LS Problem
I am trying to get a simple count of documents that are open. It keeps returning 0, which is not the case.
Dim db As New NotesDatabase( “”, “vhd.nsf” )
Dim collection As NotesDocumentCollection
Dim vw As NotesView
Set vw = db.GetView(“SCMonthlyReport”)
If vw Is Nothing Then
MessageBox "No View"
Exit Sub
Set collection = vw.Getalldocumentsbykey(“Open”, false)
MessageBox collection.Count
Subject: Some questions
Some questions :
  1. Is vhd.nsf the database you develop in ?
If yes, modify your code by replacing :
with :
dim session as new notessession
dim db as NotesDatabase
set db=session.CurrentDatabase
  1. Control the your view SCMonthlyReport has the data you search for in the first column AND that this first column is sorted. It doesn’t matter if it’s ascending or descending but it has to be sorted.
Hope this helps
Renaud
Subject: Re: beginner LS Problem
Your problem might be the fact that you’re trying to feed your messagebox with an integer.Try msgbox Cstr(collection.count)
