'Begin MIME to CD Conversion.....' in Applications
Hello All
I’m having problems with my Domino Server R6.0.1CF1 running with Windows 2000 Server SP2.
I have some web applications running on my server, and when everybody access my intranet applications, shows the messages below at my Domino Console. Its shows every time and my log are full of this items. Sometimes the server running low because there are many users accessing the applications. If you only refresh your web browser, shows this messages at Domino console.
25/04/2003 17:19:29 Begin MIME to CD Conversion (Process: ? (0000025C:00000022), Database: D:\Lotus\Domino\Data\aplica\xxx.nsf, Note: 00007EA2)
25/04/2003 17:19:29 End MIME to CD Conversion (Process: ? (0000025C:00000022), Database: D:\Lotus\Domino\Data\aplica\xxx.nsf, Note: 00007EA2)
25/04/2003 17:19:30 End MIME to CD Conversion (Process: ? (0000025C:00000022), Database: D:\Lotus\Domino\Data\aplica\xxx.nsf, Note: 00007EA2)
Please some one help me to resolve this problem.
Leonardo Costa
Subject: Set converter_log_level=10 in your server’s notes.ini and the logging will stop.
Subject: RE: Set converter_log_level=10 in your server’s notes.ini and the logging will stop.
Hi Thomas
I have added this entry to our Notes.ini on our server but it has not stopped the logging of “Begin MIME to CD Conversion…” and “End MIME to CD Conversion…” Do I have to stop and restart our Notes server in order for this to work?
Sean
if you’ve done everything correctly, that should do it without any need to restart the server (or any server component; e.g., the router).
pwl
ibm m&c
