Bbmgrw32.exe problem
Hi @all I am having this problem… for this reason i will copy and paste this topic again from the Lotus Mobile Connect forum -----copy----
Somebody expirence in BlackBerry Enterprise Server 4 and Domino 8.0.2?
Thirst my problem: I receive the error message “Process C:\Program Files\BlackBerry Enterprise Server\BBMgr\Server\bbmgrw32.exe (1592/0x638) has terminated abnormally” wereas the path, where the program is located (I think) isn’t important. My question is, why I receive this message? Al seams to be run perfect… mails ar beeing deliverd, Domino server and BB Enterprise Server are runging… but after a task os session (I dont know in which constellation) I receive the error bellow.
Any Idee why?
–end–
I found this article in BB
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB13512&sliceId=SAL_Public&dialogID=202350362&stateId=1%200%20202344977
any solution is explained
Thank you
Subject: Fix is from domino 7, but appears to apply
http://www-01.ibm.com/support/docview.wss?uid=swg21280112
