I have one desktop and one laptop, due to bad performance on desktop, I swiched Notes into Basic Mode. Yesterday I got a new laptop, after install Notes client, everything went smoothly but right after I close Notes and re-open, the Notes interface turned into Basic Mode.
I tried to remove data folder, re-install Notes client, no matter what I did, it turned into basic.
I also let my slow desktop machine back into standard Notes 8.5 interface, and copied all data folder and overwrote my laptop Notes data folder, and it didn’t work.
Now my desktop is standard mode and my laptop is basic mode, I re-installed Notes client for over 10 times yesterday.
Thanks for your reply. Don’t know why the problem seems to happen randomly, this morning I open Notes, and it’s basic mode, and 5 minutes ago after I restart laptop, now the Notes is in standard mode, don’t know if it would turn back to basic mode next time I start the system.
I checked Notes.ini, it’s strange, I can’t locate where the file is, I knew I can change Notes into basic mode by adding “UseBasicNotes=1” in it, but somehow, I found no such file in my computer anymore. I copied that file from my dedktop into my laptop and open Notes, it’s still in basic mode ( I checked no “UseBasicNotes=1” in that file). Also, I checked start menu shortcut, no so called “-sa” at the end of the program path.
