Basic Mode Issue
Hi Lotus Gurus,
Our application displays popup then launches the form, in basic mode it displays form first and then the popup.
Whereas in standard mode it displays popup then the form. This happening in Lotus Notes Client 8.5.3.
Thanks,
Pervela Mallik Ram Sharma
Subject: Post the relevant code…
  1. Strip down the code to a bare minimum, but where it still exhibits the behaviour you ar ereporting.
  2. Post that code here.
Hi Karl,
Thanks for your reply.
In fact the code is confidential, however it is simple code.
Can you please help us in this regard?
Thanks,
P. Mallik Ram
Subject: Confidential code
If the code is that confidential, it is hard to help you. I can’t see how 5-6 lines of relevant code can be causing any problems posting.
Strip the code of everything that is confidential (server names, etc). You do understand the concept of “only relevant code”? That means that you delete all code around it and isolate the problem in just a few lines. If teh problem is still showing up, you post the code here and we can take a look at it.
Since what you are describing should be able to be duplicated in just a few lines, there should be no risk of posting those 5-6 lines here.
