Autoreply and Body
HiI use this script when a do a autoreply. The problem is that the content in the bodyfield don´t work. It´s empty when it come back. What have a done wrong.
Sub Initialize
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim Item As NotesItem
Dim Item2 As NotesItem
Dim Item3 As NotesItem
Dim maildoc As NotesDocument
Dim upperBound As Integer
Dim buildsubject As String
Dim SearchView As NotesView
Dim activeDoc As NotesDocument
Dim rtitem As NotesRichTextItem
Dim docColl As NotesDocumentCollection
'Set email distribution list
Print "Starting AutoreplyMessage Agent"
Set maildoc = New NotesDocument( db )
Set profileDoc = db.GetProfileDocument("KeyWords")
'Set the To, Subject and Body fields
maildoc.Form="Memo"
maildoc.SendTo=profileDoc.ServerMail(0)
sender=profileDoc.ServerMail2(0)+profileDoc.DomainMail(0)
maildoc.from=sender
maildoc.SMTPOriginator=sender
maildoc.Principal=sender
'Format the document
buildsubject = doc.Subject(0)
maildoc.Subject = buildsubject
'BODY
Set rtitem = New NotesRichTextItem(doc,"Body")
Call rtitem.appendtext(Body)
Call maildoc.Send(False)
Kind regards
Fredrik
Subject: Autoreply and Body
This line does notlook right to me:
What is Body?
Please add Option Explicit/Option Declare in your script; this will gard you against these type of errors.
