Hello, I need a Linux auto startup script for Sametime Community and proxy servers. I tried this below script for proxy, it stops the proxy service properly however it is unable to start it automatically. Please do help. Thank you in advance.
useradd -m -U -d /opt/hcl/sametimeproxy/ -s /bin/false tomcat
chown -R tomcat: /opt/hcl/sametimeproxy/
vim /etc/systemd/system/tomcat.service
[Unit]
Description=ST Proxy Tomcat 9 servlet container
After=network.target
[Service]
Type=forking
User=tomcat
Group=tomcat
Environment=“JAVA_HOME=/opt/hcl/sametimeproxy/jdk8u222-b10-jre”
Environment=“CATALINA_BASE=/opt/hcl/sametimeproxy”
Environment=“CATALINA_HOME=/opt/hcl/sametimeproxy”
Environment=“CATALINA_PID=/opt/hcl/sametimeproxy/temp/tomcat.pid”
Environment=“CATALINA_OPTS=-Xms512M -Xmx1024M -server -XX:+UseParallelGC”
ExecStart=/opt/hcl/sametimeproxy/bin/startup.sh
ExecStop=/opt/hcl/sametimeproxy/bin/shutdown.sh
[Install]
WantedBy=multi-user.target
systemctl daemon-reload
systemctl enable tomcat
systemctl stop tomcat
Sametime proxy auto startup script - https://hclpnpsupport.hcltech.com/csm?id=kb_article&sys_id=39195edf1bbeccdcc13e748edc4bcbbb
Regards,
Elango
This seems to be a correct service file.
As it is not able to start the server I assume that you have changed the ports of the proxy server to be in the protected range below 1024. Most probably you chose ports 80 and 443 as this is what users most times expect.
But linux does not allow non- root- users to use so called "Priviledged Ports".
One possible solution for this would be to change back the ports to something above 1024 and then setup a port forwarding via iptables or an nginx server that redirects the "expected" ports to the ones the tomcat is listening on.
Here on Stackoverflow you can read all about multiple ways to do this and why use some and not others. Attention: It's lot of stuff to read...
Hi Torsten, Yes I got your point.
I already changed the port from default to 443 in the ST proxy server. Is there any other solutions for this apart from the port forwarding or using a reverse proxy in front of the ST proxy server.
I did not find a working solution for me to circumvent this linux security restrictions. I am not a linux professional and therefor had to google a lot.
And if you read about solutions like "authbind" or "setcap" you find a lot of reasons to NOT use them...
Thats why I changed back the ports to the original ones and for my server used an nginx reverse proxy...
Of course my solution was just to "play around" a little bit. At our customers I work close with the linux admins there, and they set up this stuff as they know exactly what they are doing...
Since this is FP1 - Check the JAVA_HOME variable in your startup script - it changed in FP1 compared to the TN that was written for 11.0.
Hi Anthony, Thanks for the response. I don't see jdk file in the /opt/hcl/sametimeproxy folder. I have installed Sametime proxy in the /opt/hcl/sametimeproxy.
[root@im sametimeproxy]# find. -name jdk*
[root@im sametimeproxy]# find /opt/hcl/sametimeproxy -name jdk*
[root@im sametimeproxy]# pwd
[root@im sametimeproxy]# ls
bin CONTRIBUTING.md HCL-README keygen.sh logs openjdk RUNNING.txt stproxy_optionalLib work
BUILDING.txt HCL-LICENSE install.sh lib NOTICE README.md setenv.sh temp
conf HCL-NOTICES javasharedresources LICENSE offlinedbsetup.jar RELEASE-NOTES stproxylogs.zip webapps
its located @ /opt/hcl/sametimeproxy/openjdk
Hi Tony, Thanks for the response. Yes I replaced the JAVA_HOME=/opt/hcl/sametimeproxy/openjdk then reload the systemctl but still doesn't start the service .to /opt/hcl/sametimeproxy/bin/startup.sh
It stops the proxy automatically but unable to start it. Please do help. Thank you in advance.
[root@hklsmt ~]# grep JAVA_HOME /etc/systemd/system/tomcat.service
Environment="JAVA_HOME=/opt/hcl/sametimeproxy/openjdk"
[root@hklsmt ~]#
[root@hklsmt ~]# netstat -tulpn |grep 443
[root@hklsmt ~]#
[root@hklsmt ~]# systemctl start tomcat
[root@hklsmt ~]#
[root@hklsmt ~]#
[root@hklsmt ~]# /opt/hcl/sametimeproxy/bin/startup.sh
Using CATALINA_BASE: /opt/hcl/sametimeproxy
Using CATALINA_HOME: /opt/hcl/sametimeproxy
Using CATALINA_TMPDIR: /opt/hcl/sametimeproxy/temp
Using JRE_HOME: /opt/hcl/sametimeproxy/openjdk
Using CLASSPATH: /opt/hcl/sametimeproxy/bin/bootstrap.jar:/opt/hcl/sametimeproxy/bin/tomcat-juli.jar
Tomcat started.
tcp6 0 0 :::443 :::* LISTEN 605973/java
[root@hklsmt ~]# systemctl stop tomcat
[root@hklsmt ~]#
Also kindly share the auto startup script for Sametime Community service in Linux - RHEL 8.1
Does anyone have an idea of the startup issue?
I have logged a case with HCL, the case is with the Extended team.
Sametime proxy auto startup | CentOS 8.1 | Sametime 11.0 FP1 | ST proxy port 443
chown -R root:root /opt/hcl/sametimeproxy/
[Unit]
[Service]
Type=forking
User=root
Group=root
Environment=“JAVA_HOME=/opt/hcl/sametimeproxy/openjdk”
[Install]
Sametime Community auto startup | CentOS 8.1 | ST 11.0 FP1 | Using Daniel's script
Download and extract Daniel script - start_script.tar
Install the script using this command - ./install_script
Edit this file - vim /opt/nashcom/startscript/rc_domino_script
Please search this - LD_LIBRARY_PATH=$Notes_ExecDirectory:$LD_LIBRARY_PATH
Please append this - ( :$Notes_ExecDirectory/sticc)
LD_LIBRARY_PATH=$Notes_ExecDirectory:$LD_LIBRARY_PATH:$Notes_ExecDirectory/sticc
From This:
if [ ${LARCH} = “sunspa” ]; then
export LD_LIBRARY_PATH
fi
if [ ${LARCH} = “linux” ]; then
fi
Modify like this:
fi
fi
Save and close the file.
systemctl enable domino.service
systemctl start domino
Thanks to @Anthony Payne
