Author Field Help
Hi
Need your help.
Database ACL: Default Reader Access
*/Domainname:Author Access
In the Author Field :Group Name Exists.
Can Group User edit the document or not?
Subject: Author Field Help
If the user is a member of the group that is in the Author field and is certified by the certifier in the ACL that has Author access assigned to it.
Subject: RE: Author Field Help
Thanks , You mean , Group Is not listed in the ACL , But still user can access , becoz group is listed in the Author Field
correct
