I have a richtext field named “xyz”.From a button i am attaching some attachments.but the attachments are not showing in a serial manner.Everytime the attachment is getting attached at first position.How can I change the cursor position to the right??What is the solution.Please help.I am writing the following code–>
@Command([EditGotoField];“xyz”);
@Command([EditInsertFileAttachment])
Subject: attachment problem
Try this:
@Command( [EditRight]; “1” ) ;
@Command([EditInsertFileAttachment]);
Regards
Litty Joseph
Subject: RE: attachment problem
Hi Joseph,
Thanks for your response.But the formalae doesnot executes.
Its giving a message-“Cannot execute the specific command”
Pls help me
Try @Command([EditBottom]) instead of EditRight I had mentioned earlier.
Regards
Litty Joseph
I have tried with all @commands like editright,editbottom etc.but its showing the same error message.Can you tell me how can i do this using lotus script like notesrichtextnavigator,notesrichtextitem like that??
You suggesstion will be appreciable.Also if u have the code then pls send me.its urgent
Was the document in Edit mode when you use this button? Otherwise first make it in edit mode using @Command( [EditDocument] ).
Regards
Litty Joseph
