Attachment Problem
Hi:
I have a pc with lotus client 8.5.1. and when I try to download attachments from emails, I double click and I do not see the window that provides the option to open, edit, view, save and cancel, the same way to attach the window will not be seen.
What can i do?
For your help and attention
Thank you
Daniel
Subject: hm
sometimes the dialogs are not showed , this is probably because of the Eclipse UI.
try and open you mail without the Eclipse ui and see if it work
there is a key combination for this, do not remember right now, CTRL+SHIFT+Openmail or CTRL-ALT+Openmail or something else :wink:
Good Luck
Thomas
http://www.notessidan.se
Subject: Check
Hi Thomas,
i’m going to check it and i let you know.
If there any way to unnistall the eclipse addons??
Thank You
Daniel
