my problem is i cannot attach attechment from one rich text filed to another rich text filed by using script if any body have code please help me its urgent
thanks in advance
thanks in advance
Subject: Attachment problem in richtextfield
Hi…Try this…
Body is one Rich Text Field
Body 1 is the one in which you want to copy the attachment
rt is also a richtextfield
Dim rtnav As NotesRichTextNavigator
Set rtnav=body.CreateNavigator
Set embob1=rtnav.GetFirstElement(8) //// Gets the First /////////Attachment in the rich text field— “body”
Set rt=embob1.Parent
Call body1.AppendRTItem(rt)
This would actually put the attached file in another RT field.
There is no direct method to copy attachment from one richtext field to another.
This is working fine… If you face any problem then get back to me,…
If it works fine for you then just leave a thank you note ![]()
Subject: RE: Attachment problem in richtextfield
thanks rohit for your responce
