Hello!
I have a first problem using attachement in a mail. (I will speak about the second one in another mail).
I create a memo with an attachement. Before sending it, I wanted to open it and modify it from the memo.
When I return to the memo, and if I try to send it I have the following error:
“Error: it is impossible to load the file : c:\temp\webaccess\xxx.doc”
Do you know this error?
Thank you if you can help me
best regards
Christelle
