As400 db2 connection problem, need help please
This web app was created on local, when placed on the server it crashes. On crashing, TCP/IP re-starts and consistency checking is performed.
Here are snippets of the code:
Options
Uselsx “*LSXODBC”
Declarations
Dim conAS400 As ODBCConnection
Dim dbNotes As NotesDatabase
Dim sesNotes As NotesSession
Initialize
Set sesNotes = New NotesSession
Set dbNotes = sesNotes.CurrentDatabase
If Not fcnLogon Then
Exit Sub
RetrieveInfo (parm1), (parm2), (parm3)
conAS400.Disconnect
fcnLogon()
Set conAS400 = New ODBCConnection
REM* Connect to as400.
If Not conAS400.ConnectTo(strDataSource, strUserName$, strPassWord$) Then
Exit Function
Sub RetrieveInfo()
Dim resOverview As New ODBCResultSet
Set resOverview = New ODBCResultSet
Set resOverview.Connection = conAS400
Call resOverview.ExecProcedure(“XXXX”,"XXXX ", strPassData)
It seems to crash on the “Set resOverview.Connection = conAS400” statement.
Prior to getting to this part of the code, it does two sql’s to retrieve some other data. Then it does several call to stored procedures, this one is the first stored procedure.
This worked fine on local… I’m stumped. I sure hope someone can help me.
Subject: as400 db2 connection problem, need help please
Hello friends…i must join to Terry request of Help…it also happens to me that migrating from Lotus 4.6.7 to Domino 6 my scripts and agents connecting to AS400 don’t work anymore!!! I changed all the methods from lsxdb2 DLL to lsxodbc ones… but every script stops when it calls the connection…
I really hope that someone help us…'cause i forced a lot my boss to migrate to D6.
Thanks in advance to all of you.
Regards, Daniele.
Did you try checking conAS400.IsConnected to make sure it is still a valid connection?
