I posted my problem two three days back,but could not get the solution,my problem ishttp://www-10.lotus.com/ldd/nd6forum.nsf/ShowMyTopicsAllThreadedweb/06ef83b74d791cbd85256fbd003a0c7d?OpenDocument
Subject: Array Unique problem
Try this:
Dim rcategory(0 To 5) As String
Dim uniquearray() As String
Dim bIsThere As Variant
Dim iCount As Integer
rcategory(0)="Allan"
rcategory(1)="Dali"
rcategory(2)="Dali"
rcategory(3)="Donald"
rcategory(4)="Allan"
rcategory(5)="Dali"
Forall a In rcategory
bIsThere = False
Forall b In uniquearray
If a = b Then
bIsThere = True
Exit Forall
End Forall
If bIsThere = False Then
Redim Preserve uniquearray(0 To iCount) As String
uniquearray(iCount) = a
iCount = iCount + 1
End Forall
Subject: Got it
Yes I got it thanks a Lot.
Regards
