Array problem
Good morning, My problem is how to use array correct. I have a form with a “repeat” field, “repeat” field contains a text list, such as “15/12/2006”,“16/12/2006”,“17/12/2006”. I would like to create new documents based on the repeat field. in this case, I want to create 3 documents as the repeat field contains 3 list.
the code below does not work, I know there are some problems with the repeat field, but I don’t know how to fix it.
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim ndoc As NotesDocument
Set doc = Source.document
If  Ubound(Source.Document.repeat(0))>1 Then
	For i=1 To Ubound(Source.Document.repeat(0))
		Set ndoc=db.CreateDocument
		ndoc.form="Reservation"
		ndoc.ReservedBy=doc.ReservedBy(0)
		ndoc.sDate=doc.repeate(i)
		ndoc.eDate=""
		ndoc.ResourceName=doc.ResourceName(0)
		ndoc.Description=doc.Description(0)
		Call ndoc.Save( False, True )
	Next
the error message is “Type mismatch”.
Many thanks for help!
Linda
Subject: Array problem.
This maybe an issue… you added an ‘e’ to repeat. This would cause your error as that field does not exist.
G.
is there a typo here?
should it be
ndoc.sDate=doc.repeat(i)
Subject: RE: Array problem.
Thanks Nancy. I change the code to ndoc.sDate=CDat(doc.repeate(i))
but the problem is on this line:
if Ubound(Source.Document.repeat(0)>1 then
Any suggestions please!
Thanks,
Linda
this is your problem: If Ubound(Source.Document.repeat(0))>1 Then
You should be doing a forall over repeat.values:
Dim item As NotesItem
Set item = source.document.GetFirstItem( “repeat” )
Forall v In item.Values
ndoc.form=“Reservation”
ndoc.sDate=v
ndoc.eDate=“”
End Forall
Thank you so much Peter. It works fine. That is what I want.
Once again. Thanks!! :slight_smile:
Linda
BTW, your code before looks fine. The bug appears to be that you started your array reference at 1 instead of 0 (assuming the you don’t have Option Base 1 declared).
Anyhow, I think that the ForAll approach is superior, IMHO.
