Archive Problem - Urgent
Dear all,I setup an archive to be performed on local from my mail server. I then manually selected archived documents and run the archive.
The status of archived was successfully done and the selected documents were deleted from my mail db but unfortunately, I couldn’t open the archived db. The message was “Database is not fully initialized yet…”
Please help on how to recover/fix my archived db because all my important docs were in there.
Thanks.
Subject: Archive Problem - Urgent.
You need to make sure the archive was created locally. It should appear in the Notes directory structure like this: C:\Program files\Lotus\Notes\Data\Archive. What this message means is that you have created a replica stub, but there are no documents in the replica yet. Which is a rather unusual error message to get when trying to view documents in an archive that you set to create immediately. Which is what leads me to believe you may have tried to create it on the server by mistake. Your Notes administrator may not be allowing the creation of archives on the server. Usually, one creates a local archive using a local replica of the mail file rather than a server based replica. Unless your Notes admin is allowing the creation of archives on the mail server. If you did try to create it on the from the server replica of your mail file, “local” would refer to the local hard drive on the server, not your hard drive.
