I’ve a domino 6.0.3 server. I configured an archiving policy for all the users in the domino directory, but the server doesn’t recognize them. He still uses the private archive settings.
Can anyone tell me what I have to do?
Mimi
Mimi
Subject: archive policy does not work
Archiving does not occur until a COMPACT event occurs.For Client to Server, archiving will occur after you run COMPACT -A on the server, usually defined in a Program Document for scheduled execution.For local archiving, there should be a Compact program running in the $Programs view in the local Address Book created from options you selected in the Local Archive Settings of your mailfile.
Hope this helps.
Subject: RE: archive policy does not work
maybe I forgot to tell but I run the compact -a task on the server. it doesn’t help. the server doesn’t recognize the archive policy setting only the private settings.
did you try restarting the server ?
