Application performance degraded between 6.5.4 and 8.0.2 - with debug info
After upgrading to ND8 clients a number of custom apps slow down dramatically. When running an ND6 client right next to an ND8 client going against the same exact database on the same server across the same network ND8 is MUCH slower.
I put client_clock=1 on both machines and I’m getting dramatically different results from the same action on the two different machines.
I put the debug info for opening a single document in each of the databases below. There are a load of dblookup/dbcolumns in the form. You will note that the debug for ND8 is about 600 lines long whereas the ND6 debug is only about 100.
Anyone have any ideas?? Could it be something with the design collection? Or is ND8 really interpreting what it needs to do with the formula language that differently???
Here is the results of the debugs.
Thanks!
Rob
Start ND6 DEBUG
(44-105 [44]) OPEN_NOTE(REP88256563:00762416-NT004315EA,06400036): 0 ms. [48+2648=2696]
(45-105 [45]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(46-105 [46]) OPEN_COLLECTION(REP88256563:00762416-NT00000A0A,0000,0000): 15 ms. [42+34=76]
(47-105 [47]) FIND_BY_KEY: 0 ms. [540+34=574]
(48-105 [48]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(49-105 [49]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(50-105 [50]) FIND_BY_KEY: 0 ms. [540+34=574]
(51-105 [51]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(52-105 [52]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(53-105 [53]) FIND_BY_KEY: 0 ms. [540+34=574]
(54-105 [54]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(55-105 [55]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(56-105 [56]) FIND_BY_KEY: 0 ms. [540+34=574]
(57-105 [57]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 16 ms. [76+630=706]
(58-105 [58]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(59-105 [59]) FIND_BY_KEY: 0 ms. [540+34=574]
(60-105 [60]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(61-105 [61]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(62-105 [62]) FIND_BY_KEY: 0 ms. [540+34=574]
(63-105 [63]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(64-105 [64]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(65-105 [65]) FIND_BY_KEY: 0 ms. [540+34=574]
(66-105 [66]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(67-105 [67]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 16 ms. [48+3152=3200]
(68-105 [68]) FIND_BY_KEY: 0 ms. [540+34=574]
(69-105 [69]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(70-105 [70]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(71-105 [71]) FIND_BY_KEY: 0 ms. [540+34=574]
(72-105 [72]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(73-105 [73]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(74-105 [74]) FIND_BY_KEY: 0 ms. [540+34=574]
(75-105 [75]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(76-105 [76]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(77-105 [77]) FIND_BY_KEY: 0 ms. [540+34=574]
(78-105 [78]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(79-105 [79]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(80-105 [80]) FIND_BY_KEY: 0 ms. [540+34=574]
(81-105 [81]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(82-105 [82]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(83-105 [83]) FIND_BY_KEY: 0 ms. [540+34=574]
(84-105 [84]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(85-105 [85]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(86-105 [86]) FIND_BY_KEY: 0 ms. [540+34=574]
(87-105 [87]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(88-105 [88]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(89-105 [89]) FIND_BY_KEY: 16 ms. [540+34=574]
(90-105 [90]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(91-105 [91]) FIND_BY_KEY: 0 ms. [540+34=574]
(92-105 [92]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(93-105 [93]) FIND_BY_KEY: 0 ms. [540+34=574]
(94-105 [94]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(95-105 [95]) FIND_BY_KEY: 0 ms. [540+34=574]
(96-105 [96]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(97-105 [97]) FIND_BY_KEY: 0 ms. [540+34=574]
(98-105 [98]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(99-105 [99]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(100-105 [100]) FIND_BY_KEY: 0 ms. [540+34=574]
(101-105 [101]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(102-105 [102]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 16 ms. [48+3152=3200]
(103-105 [103]) FIND_BY_KEY: 0 ms. [540+34=574]
(104-105 [104]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(105-105 [105]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(106-105 [106]) FIND_BY_KEY: 0 ms. [540+34=574]
(107-105 [107]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(108-105 [108]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 0 ms. [48+3152=3200]
(109-105 [109]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(110-105 [110]) OPEN_COLLECTION(REP88256563:00762416-NT00000B7E,0000,0000): 0 ms. [42+34=76]
(111-105 [111]) FIND_BY_KEY: 0 ms. [540+34=574]
(112-105 [112]) READ_ENTRIES(REP88256563:00762416-NT00000B7E): 0 ms. [76+324=400]
(113-105 [113]) FIND_BY_KEY: 15 ms. [540+34=574]
(114-105 [114]) READ_ENTRIES(REP88256563:00762416-NT00000B7E): 0 ms. [76+324=400]
(115-105 [115]) OPEN_DB(CN=NYC/O=LV_Notes!!Corner\tables.nsf): 0 ms. [134+290=424]
(116-105 [116]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(117-105 [117]) OPEN_COLLECTION(REP8825654B:006B2EE6-NT0000030A,0000,0000): 0 ms. [42+34=76]
(118-105 [118]) READ_ENTRIES(REP8825654B:006B2EE6-NT0000030A): 0 ms. [76+240=316]
(119-105 [119]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(120-105 [120]) OPEN_COLLECTION(REP8825654B:006B2EE6-NT000003AA,0000,0000): 0 ms. [42+34=76]
(121-105 [121]) READ_ENTRIES(REP8825654B:006B2EE6-NT000003AA): 0 ms. [76+128=204]
(122-105 [122]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(123-105 [123]) OPEN_COLLECTION(REP8825654B:006B2EE6-NT00000352,0000,0000): 0 ms. [42+34=76]
(124-105 [124]) READ_ENTRIES(REP8825654B:006B2EE6-NT00000352): 0 ms. [76+2734=2810]
(125-105 [125]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(126-105 [126]) OPEN_COLLECTION(REP88256563:00762416-NT00205022,0000,0000): 0 ms. [42+34=76]
(127-105 [127]) FIND_BY_KEY: 0 ms. [540+38=578]
(128-105 [128]) READ_ENTRIES(REP88256563:00762416-NT00205022): 0 ms. [80+400=480]
(129-106 [129]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(130-106 [130]) OPEN_COLLECTION(REP8825654B:006B2EE6-NT00000316,0000,0000): 0 ms. [42+34=76]
(131-106 [131]) READ_ENTRIES(REP8825654B:006B2EE6-NT00000316): 0 ms. [76+196=272]
(132-106 [132]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(133-106 [133]) OPEN_COLLECTION(REP8825654B:006B2EE6-NT00011972,0000,0000): 0 ms. [42+34=76]
(134-106 [134]) READ_ENTRIES(REP8825654B:006B2EE6-NT00011972): 0 ms. [76+356=432]
(135-106 [135]) OPEN_DB(CN=NYC/O=LV_Notes!!CORNER\DocRepo.nsf): 0 ms. [134+290=424]
(136-106 [136]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03000400): 0 ms. [48+5644=5692]
(137-106 [137]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(138-106 [138]) OPEN_COLLECTION(REP88256F35:00669FD1-NT00057A5E,0000,0000): 0 ms. [42+804=846]
(139-106 [139]) READ_ENTRIES(REP88256F35:00669FD1-NT00057A5E): 0 ms. [114+1762=1876]
(140-106 [140]) CLOSE_COLLECTION(REP88256F35:00669FD1-NT00057A5E): 0 ms. [12+0=12]
(141-106 [141]) DB_MODIFIED_TIME: 141 ms. [14+68=82]
(142-106 [142]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(143-106 [143]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(144-106 [144]) DB_INFO_GET: 0 ms. [14+140=154]
(145-106 [145]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03400000): 0 ms. [48+5330=5378]
(146-106 [146]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03400000): 0 ms. [48+5330=5378]
(147-106 [147]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03000400): 0 ms. [48+5644=5692]
(148-106 [148]) OPEN_COLLECTION(REP88256F35:00669FD1-NT0000056A,0060,0000): 500 ms. [78+34=112]
(149-106 [149]) GET_NOTE_INFO: 0 ms. [18+102=120]
(150-106 [150]) SET_COLLATION: 0 ms. [14+12=26]
(151-106 [151]) FIND_BY_KEY: 0 ms. [540+26=566] (Entry not found in index)
(152-106 [152]) READ_ENTRIES(REP88256F35:00669FD1-NT0000056A): 0 ms. [80+96=176]
(153-106 [153]) READ_ENTRIES(REP88256F35:00669FD1-NT0000056A): 0 ms. [76+1798=1874]
(154-107 [154]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(155-107 [155]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,03400001): 0 ms. [48+4654=4702]
(156-107 [156]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+466=542]
(157-107 [157]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,07400002): 0 ms. [48+3152=3200]
Start ND8 Debug INFO
(3352-1066 [3352]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 4 ms. [48+10884=10932]
(3353-1066 [3353]) NIF_OPEN_NOTE(REP88256563:00762416-NT004315EA,02000136): 1 ms. [42+2770=2812]
(3354-1066 [3354]) DB_MODIFIED_TIME: 1 ms. [14+152=166]
(3355-1066 [3355]) GET_NAMED_OBJECT_ID($PrivateDesign): 133 ms. [40+108=148]
(3356-1066 [3356]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 14 ms. [42+888=930]
(3357-1066 [3357]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3358-1066 [3358]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3359-1066 [3359]) DB_MODIFIED_TIME: 215 ms. [14+68=82]
(3360-1066 [3360]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3361-1066 [3361]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3362-1066 [3362]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3363-1066 [3363]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3364-1066 [3364]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3365-1066 [3365]) DB_MODIFIED_TIME: 211 ms. [14+68=82]
(3366-1066 [3366]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3367-1066 [3367]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3368-1066 [3368]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3369-1066 [3369]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3370-1066 [3370]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3371-1066 [3371]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3372-1066 [3372]) FIND_BY_KEY: 0 ms. [540+34=574]
(3373-1066 [3373]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3374-1066 [3374]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3375-1066 [3375]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3376-1066 [3376]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3377-1066 [3377]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3378-1066 [3378]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 21 ms. [130+2946=3076]
(3379-1066 [3379]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3380-1066 [3380]) DB_MODIFIED_TIME: 179 ms. [14+68=82]
(3381-1066 [3381]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3382-1066 [3382]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3383-1066 [3383]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3384-1066 [3384]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3385-1066 [3385]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3386-1066 [3386]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3387-1066 [3387]) DB_MODIFIED_TIME: 208 ms. [14+68=82]
(3388-1067 [3388]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3389-1067 [3389]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3390-1067 [3390]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3391-1067 [3391]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3392-1067 [3392]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3393-1067 [3393]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 2 ms. [48+4654=4702]
(3394-1067 [3394]) FIND_BY_KEY: 1 ms. [540+34=574]
(3395-1067 [3395]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3396-1067 [3396]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3397-1067 [3397]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3398-1067 [3398]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3399-1067 [3399]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3400-1067 [3400]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 18 ms. [130+2946=3076]
(3401-1067 [3401]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3402-1067 [3402]) DB_MODIFIED_TIME: 181 ms. [14+68=82]
(3403-1067 [3403]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3404-1067 [3404]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3405-1067 [3405]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3406-1067 [3406]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3407-1067 [3407]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 7 ms. [130+2946=3076]
(3408-1067 [3408]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3409-1067 [3409]) DB_MODIFIED_TIME: 202 ms. [14+68=82]
(3410-1067 [3410]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3411-1067 [3411]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3412-1067 [3412]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3413-1067 [3413]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3414-1067 [3414]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3415-1067 [3415]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3416-1067 [3416]) FIND_BY_KEY: 0 ms. [540+34=574]
(3417-1067 [3417]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3418-1067 [3418]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3419-1067 [3419]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3420-1067 [3420]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3421-1067 [3421]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 21 ms. [42+804=846]
(3422-1067 [3422]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 2 ms. [130+2946=3076]
(3423-1067 [3423]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3424-1067 [3424]) DB_MODIFIED_TIME: 180 ms. [14+68=82]
(3425-1067 [3425]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3426-1067 [3426]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3427-1067 [3427]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3428-1067 [3428]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3429-1067 [3429]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 2 ms. [130+2946=3076]
(3430-1067 [3430]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3431-1067 [3431]) DB_MODIFIED_TIME: 207 ms. [14+68=82]
(3432-1067 [3432]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3433-1067 [3433]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3434-1067 [3434]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3435-1067 [3435]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3436-1067 [3436]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3437-1067 [3437]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 2 ms. [48+4654=4702]
(3438-1067 [3438]) FIND_BY_KEY: 1 ms. [540+34=574]
(3439-1067 [3439]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3440-1067 [3440]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3441-1067 [3441]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3442-1067 [3442]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3443-1067 [3443]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3444-1067 [3444]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 7 ms. [130+2946=3076]
(3445-1067 [3445]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3446-1067 [3446]) DB_MODIFIED_TIME: 192 ms. [14+68=82]
(3447-1068 [3447]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3448-1068 [3448]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3449-1068 [3449]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3450-1068 [3450]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3451-1068 [3451]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3452-1068 [3452]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3453-1068 [3453]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3454-1068 [3454]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3455-1068 [3455]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3456-1068 [3456]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3457-1068 [3457]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3458-1068 [3458]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(3459-1068 [3459]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3460-1068 [3460]) FIND_BY_KEY: 0 ms. [540+34=574]
(3461-1068 [3461]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3462-1068 [3462]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3463-1068 [3463]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3464-1068 [3464]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3465-1068 [3465]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3466-1068 [3466]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3467-1068 [3467]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3468-1068 [3468]) DB_MODIFIED_TIME: 199 ms. [14+68=82]
(3469-1068 [3469]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3470-1068 [3470]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3471-1068 [3471]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3472-1068 [3472]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3473-1068 [3473]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 25 ms. [130+2946=3076]
(3474-1068 [3474]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3475-1068 [3475]) DB_MODIFIED_TIME: 185 ms. [14+68=82]
(3476-1068 [3476]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3477-1068 [3477]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3478-1068 [3478]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3479-1068 [3479]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3480-1068 [3480]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(3481-1068 [3481]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3482-1068 [3482]) FIND_BY_KEY: 1 ms. [540+34=574]
(3483-1068 [3483]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3484-1068 [3484]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3485-1068 [3485]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3486-1068 [3486]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3487-1068 [3487]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 6 ms. [42+804=846]
(3488-1068 [3488]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3489-1068 [3489]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3490-1068 [3490]) DB_MODIFIED_TIME: 192 ms. [14+68=82]
(3491-1069 [3491]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3492-1069 [3492]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3493-1069 [3493]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3494-1069 [3494]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3495-1069 [3495]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3496-1069 [3496]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3497-1069 [3497]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3498-1069 [3498]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3499-1069 [3499]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3500-1069 [3500]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3501-1069 [3501]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3502-1069 [3502]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3503-1069 [3503]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3504-1069 [3504]) FIND_BY_KEY: 0 ms. [540+34=574]
(3505-1069 [3505]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3506-1069 [3506]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3507-1069 [3507]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3508-1069 [3508]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3509-1069 [3509]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3510-1069 [3510]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 10 ms. [130+2946=3076]
(3511-1069 [3511]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3512-1069 [3512]) DB_MODIFIED_TIME: 190 ms. [14+68=82]
(3513-1069 [3513]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3514-1069 [3514]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3515-1069 [3515]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3516-1069 [3516]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3517-1069 [3517]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3518-1069 [3518]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3519-1069 [3519]) DB_MODIFIED_TIME: 208 ms. [14+68=82]
(3520-1069 [3520]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3521-1069 [3521]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3522-1069 [3522]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3523-1069 [3523]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3524-1069 [3524]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(3525-1069 [3525]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3526-1069 [3526]) FIND_BY_KEY: 1 ms. [540+34=574]
(3527-1069 [3527]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3528-1069 [3528]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 2 ms. [48+3152=3200]
(3529-1069 [3529]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3530-1069 [3530]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3531-1069 [3531]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3532-1069 [3532]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 18 ms. [130+2946=3076]
(3533-1069 [3533]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3534-1069 [3534]) DB_MODIFIED_TIME: 182 ms. [14+68=82]
(3535-1069 [3535]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3536-1069 [3536]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3537-1069 [3537]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3538-1069 [3538]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3539-1069 [3539]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3540-1069 [3540]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3541-1069 [3541]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3542-1070 [3542]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3543-1070 [3543]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3544-1070 [3544]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3545-1070 [3545]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3546-1070 [3546]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3547-1070 [3547]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3548-1070 [3548]) FIND_BY_KEY: 0 ms. [540+34=574]
(3549-1070 [3549]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3550-1070 [3550]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3551-1070 [3551]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3552-1070 [3552]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3553-1070 [3553]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3554-1070 [3554]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3555-1070 [3555]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3556-1070 [3556]) DB_MODIFIED_TIME: 157 ms. [14+68=82]
(3557-1070 [3557]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3558-1070 [3558]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3559-1070 [3559]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3560-1070 [3560]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3561-1070 [3561]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3562-1070 [3562]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3563-1070 [3563]) DB_MODIFIED_TIME: 145 ms. [14+68=82]
(3564-1070 [3564]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3565-1070 [3565]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3566-1070 [3566]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3567-1070 [3567]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3568-1070 [3568]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(3569-1070 [3569]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3570-1070 [3570]) FIND_BY_KEY: 0 ms. [540+34=574]
(3571-1070 [3571]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3572-1070 [3572]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3573-1070 [3573]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3574-1070 [3574]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3575-1070 [3575]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3576-1070 [3576]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 2 ms. [130+2946=3076]
(3577-1070 [3577]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3578-1070 [3578]) DB_MODIFIED_TIME: 199 ms. [14+68=82]
(3579-1070 [3579]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3580-1070 [3580]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3581-1070 [3581]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3582-1070 [3582]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3583-1070 [3583]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3584-1070 [3584]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3585-1070 [3585]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3586-1070 [3586]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3587-1070 [3587]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3588-1070 [3588]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3589-1070 [3589]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3590-1070 [3590]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3591-1070 [3591]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 2 ms. [48+4654=4702]
(3592-1070 [3592]) FIND_BY_KEY: 1 ms. [540+34=574]
(3593-1070 [3593]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3594-1070 [3594]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 2 ms. [48+3152=3200]
(3595-1070 [3595]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3596-1070 [3596]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3597-1070 [3597]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3598-1070 [3598]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 20 ms. [130+2946=3076]
(3599-1070 [3599]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3600-1070 [3600]) DB_MODIFIED_TIME: 179 ms. [14+68=82]
(3601-1071 [3601]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3602-1071 [3602]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3603-1071 [3603]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3604-1071 [3604]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3605-1071 [3605]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3606-1071 [3606]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3607-1071 [3607]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3608-1071 [3608]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3609-1071 [3609]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3610-1071 [3610]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3611-1071 [3611]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3612-1071 [3612]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3613-1071 [3613]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3614-1071 [3614]) FIND_BY_KEY: 0 ms. [540+34=574]
(3615-1071 [3615]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3616-1071 [3616]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3617-1071 [3617]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3618-1071 [3618]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3619-1071 [3619]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 15 ms. [42+804=846]
(3620-1071 [3620]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3621-1071 [3621]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3622-1071 [3622]) DB_MODIFIED_TIME: 185 ms. [14+68=82]
(3623-1071 [3623]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3624-1071 [3624]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3625-1071 [3625]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3626-1071 [3626]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3627-1071 [3627]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 7 ms. [130+2946=3076]
(3628-1071 [3628]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3629-1071 [3629]) DB_MODIFIED_TIME: 202 ms. [14+68=82]
(3630-1071 [3630]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3631-1071 [3631]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3632-1071 [3632]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3633-1071 [3633]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3634-1071 [3634]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3635-1071 [3635]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3636-1071 [3636]) FIND_BY_KEY: 0 ms. [540+34=574]
(3637-1071 [3637]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3638-1071 [3638]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3639-1071 [3639]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3640-1071 [3640]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3641-1071 [3641]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3642-1071 [3642]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 13 ms. [130+2946=3076]
(3643-1071 [3643]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3644-1071 [3644]) DB_MODIFIED_TIME: 187 ms. [14+68=82]
(3645-1072 [3645]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3646-1072 [3646]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3647-1072 [3647]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3648-1072 [3648]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 8 ms. [42+804=846]
(3649-1072 [3649]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 8 ms. [130+2946=3076]
(3650-1072 [3650]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3651-1072 [3651]) DB_MODIFIED_TIME: 195 ms. [14+68=82]
(3652-1072 [3652]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3653-1072 [3653]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3654-1072 [3654]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3655-1072 [3655]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3656-1072 [3656]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3657-1072 [3657]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3658-1072 [3658]) FIND_BY_KEY: 0 ms. [540+34=574]
(3659-1072 [3659]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3660-1072 [3660]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3661-1072 [3661]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3662-1072 [3662]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3663-1072 [3663]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 7 ms. [42+804=846]
(3664-1072 [3664]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3665-1072 [3665]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3666-1072 [3666]) DB_MODIFIED_TIME: 193 ms. [14+68=82]
(3667-1072 [3667]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3668-1072 [3668]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3669-1072 [3669]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3670-1072 [3670]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3671-1072 [3671]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 15 ms. [130+2946=3076]
(3672-1072 [3672]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3673-1072 [3673]) DB_MODIFIED_TIME: 195 ms. [14+68=82]
(3674-1072 [3674]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3675-1072 [3675]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3676-1072 [3676]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3677-1072 [3677]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3678-1072 [3678]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(3679-1072 [3679]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3680-1072 [3680]) FIND_BY_KEY: 1 ms. [540+34=574]
(3681-1072 [3681]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3682-1072 [3682]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3683-1072 [3683]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3684-1072 [3684]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3685-1072 [3685]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 10 ms. [130+2946=3076]
(3686-1072 [3686]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3687-1072 [3687]) DB_MODIFIED_TIME: 191 ms. [14+68=82]
(3688-1072 [3688]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3689-1072 [3689]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3690-1072 [3690]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3691-1072 [3691]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3692-1072 [3692]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3693-1072 [3693]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3694-1072 [3694]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3695-1073 [3695]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3696-1073 [3696]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3697-1073 [3697]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3698-1073 [3698]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3699-1073 [3699]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3700-1073 [3700]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3701-1073 [3701]) FIND_BY_KEY: 0 ms. [540+34=574]
(3702-1073 [3702]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3703-1073 [3703]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3704-1073 [3704]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3705-1073 [3705]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 11 ms. [42+804=846]
(3706-1073 [3706]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 8 ms. [130+2946=3076]
(3707-1073 [3707]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3708-1073 [3708]) DB_MODIFIED_TIME: 184 ms. [14+68=82]
(3709-1073 [3709]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3710-1073 [3710]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3711-1073 [3711]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3712-1073 [3712]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3713-1073 [3713]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 9 ms. [130+2946=3076]
(3714-1073 [3714]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3715-1073 [3715]) DB_MODIFIED_TIME: 201 ms. [14+68=82]
(3716-1073 [3716]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3717-1073 [3717]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3718-1073 [3718]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3719-1073 [3719]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3720-1073 [3720]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3721-1073 [3721]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 2 ms. [48+4654=4702]
(3722-1073 [3722]) FIND_BY_KEY: 1 ms. [540+34=574]
(3723-1073 [3723]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3724-1073 [3724]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3725-1073 [3725]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3726-1073 [3726]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 12 ms. [42+804=846]
(3727-1073 [3727]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3728-1073 [3728]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3729-1073 [3729]) DB_MODIFIED_TIME: 189 ms. [14+68=82]
(3730-1073 [3730]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3731-1073 [3731]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3732-1073 [3732]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3733-1073 [3733]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3734-1073 [3734]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3735-1073 [3735]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3736-1073 [3736]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3737-1073 [3737]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3738-1073 [3738]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3739-1073 [3739]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3740-1073 [3740]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3741-1073 [3741]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(3742-1073 [3742]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3743-1073 [3743]) FIND_BY_KEY: 0 ms. [540+34=574]
(3744-1073 [3744]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3745-1073 [3745]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3746-1073 [3746]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3747-1073 [3747]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3748-1073 [3748]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3749-1073 [3749]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3750-1073 [3750]) DB_MODIFIED_TIME: 201 ms. [14+68=82]
(3751-1074 [3751]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3752-1074 [3752]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3753-1074 [3753]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3754-1074 [3754]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3755-1074 [3755]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3756-1074 [3756]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3757-1074 [3757]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3758-1074 [3758]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3759-1074 [3759]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3760-1074 [3760]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3761-1074 [3761]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3762-1074 [3762]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3763-1074 [3763]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 2 ms. [48+4654=4702]
(3764-1074 [3764]) FIND_BY_KEY: 1 ms. [540+34=574]
(3765-1074 [3765]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3766-1074 [3766]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 2 ms. [48+3152=3200]
(3767-1074 [3767]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3768-1074 [3768]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3769-1074 [3769]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 12 ms. [42+804=846]
(3770-1074 [3770]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3771-1074 [3771]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3772-1074 [3772]) DB_MODIFIED_TIME: 187 ms. [14+68=82]
(3773-1074 [3773]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3774-1074 [3774]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3775-1074 [3775]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3776-1074 [3776]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3777-1074 [3777]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3778-1074 [3778]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3779-1074 [3779]) DB_MODIFIED_TIME: 204 ms. [14+68=82]
(3780-1074 [3780]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3781-1074 [3781]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3782-1074 [3782]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3783-1074 [3783]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3784-1074 [3784]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3785-1074 [3785]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 2 ms. [48+4654=4702]
(3786-1074 [3786]) FIND_BY_KEY: 1 ms. [540+34=574]
(3787-1074 [3787]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3788-1074 [3788]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 2 ms. [48+3152=3200]
(3789-1074 [3789]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3790-1074 [3790]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3791-1074 [3791]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 7 ms. [42+804=846]
(3792-1074 [3792]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 15 ms. [130+2946=3076]
(3793-1074 [3793]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3794-1074 [3794]) DB_MODIFIED_TIME: 183 ms. [14+68=82]
(3795-1075 [3795]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3796-1075 [3796]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3797-1075 [3797]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3798-1075 [3798]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3799-1075 [3799]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3800-1075 [3800]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3801-1075 [3801]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3802-1075 [3802]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3803-1075 [3803]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3804-1075 [3804]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3805-1075 [3805]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3806-1075 [3806]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3807-1075 [3807]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3808-1075 [3808]) FIND_BY_KEY: 1 ms. [540+34=574]
(3809-1075 [3809]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+630=706]
(3810-1075 [3810]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3811-1075 [3811]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3812-1075 [3812]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3813-1075 [3813]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3814-1075 [3814]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3815-1075 [3815]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3816-1075 [3816]) DB_MODIFIED_TIME: 198 ms. [14+68=82]
(3817-1075 [3817]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3818-1075 [3818]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3819-1075 [3819]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3820-1075 [3820]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3821-1075 [3821]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 10 ms. [130+2946=3076]
(3822-1075 [3822]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3823-1075 [3823]) DB_MODIFIED_TIME: 200 ms. [14+68=82]
(3824-1075 [3824]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3825-1075 [3825]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3826-1075 [3826]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3827-1075 [3827]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3828-1075 [3828]) FINDDESIGN_NOTES: 0 ms. [36+16=52]
(3829-1075 [3829]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,00400000): 1 ms. [48+4654=4702]
(3830-1075 [3830]) FIND_BY_KEY: 0 ms. [540+34=574]
(3831-1075 [3831]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 0 ms. [76+630=706]
(3832-1075 [3832]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,00400000): 1 ms. [48+3152=3200]
(3833-1075 [3833]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3834-1075 [3834]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3835-1075 [3835]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3836-1075 [3836]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 11 ms. [130+2946=3076]
(3837-1075 [3837]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3838-1075 [3838]) DB_MODIFIED_TIME: 186 ms. [14+68=82]
(3839-1075 [3839]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3840-1075 [3840]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 1 ms. [48+10884=10932]
(3841-1075 [3841]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3842-1075 [3842]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3843-1075 [3843]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3844-1075 [3844]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3845-1075 [3845]) DB_MODIFIED_TIME: 209 ms. [14+68=82]
(3846-1076 [3846]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3847-1076 [3847]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3848-1076 [3848]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3849-1076 [3849]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3850-1076 [3850]) FINDDESIGN_NOTES: 1 ms. [46+16=62]
(3851-1076 [3851]) OPEN_NOTE(REP88256563:00762416-NT00000B7E,00400000): 2 ms. [48+5434=5482]
(3852-1076 [3852]) FIND_BY_KEY: 1 ms. [540+34=574]
(3853-1076 [3853]) READ_ENTRIES(REP88256563:00762416-NT00000B7E): 1 ms. [76+324=400]
(3854-1076 [3854]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3855-1076 [3855]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3856-1076 [3856]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 9 ms. [42+804=846]
(3857-1076 [3857]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3858-1076 [3858]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3859-1076 [3859]) DB_MODIFIED_TIME: 192 ms. [14+68=82]
(3860-1076 [3860]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3861-1076 [3861]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3862-1076 [3862]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3863-1076 [3863]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 2 ms. [42+804=846]
(3864-1076 [3864]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 21 ms. [130+2946=3076]
(3865-1076 [3865]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 1 ms. [12+0=12]
(3866-1076 [3866]) DB_MODIFIED_TIME: 189 ms. [14+68=82]
(3867-1076 [3867]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3868-1076 [3868]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3869-1076 [3869]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 1 ms. [48+10464=10512]
(3870-1076 [3870]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3871-1076 [3871]) FINDDESIGN_NOTES: 1 ms. [46+16=62]
(3872-1076 [3872]) OPEN_NOTE(REP88256563:00762416-NT00000B7E,00400000): 1 ms. [48+5434=5482]
(3873-1076 [3873]) FIND_BY_KEY: 1 ms. [540+34=574]
(3874-1076 [3874]) READ_ENTRIES(REP88256563:00762416-NT00000B7E): 1 ms. [76+324=400]
(3875-1076 [3875]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3876-1076 [3876]) OPEN_NOTE(REP8825654B:006B2EE6-NT0000030A,00400000): 1 ms. [48+1462=1510]
(3877-1076 [3877]) READ_ENTRIES(REP8825654B:006B2EE6-NT0000030A): 1 ms. [76+240=316]
(3878-1076 [3878]) DB_MODIFIED_TIME: 0 ms. [14+68=82]
(3879-1076 [3879]) OPEN_NOTE(REP8825654B:006B2EE6-NT000003AA,00400000): 1 ms. [48+1476=1524]
(3880-1076 [3880]) READ_ENTRIES(REP8825654B:006B2EE6-NT000003AA): 1 ms. [76+128=204]
(3881-1076 [3881]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3882-1076 [3882]) OPEN_NOTE(REP8825654B:006B2EE6-NT00000352,00400000): 1 ms. [48+3222=3270]
(3883-1076 [3883]) READ_ENTRIES(REP8825654B:006B2EE6-NT00000352): 3 ms. [76+2734=2810]
(3884-1076 [3884]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3885-1076 [3885]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3886-1076 [3886]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3887-1076 [3887]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 1 ms. [130+2946=3076]
(3888-1076 [3888]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3889-1076 [3889]) DB_MODIFIED_TIME: 162 ms. [14+68=82]
(3890-1076 [3890]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3891-1076 [3891]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03000400): 2 ms. [48+10884=10932]
(3892-1076 [3892]) GET_NAMED_OBJECT_ID($PrivateDesign): 0 ms. [40+24=64]
(3893-1076 [3893]) OPEN_COLLECTION(REP88256563:00762416-NT004447BE,0000,0000): 1 ms. [42+804=846]
(3894-1076 [3894]) READ_ENTRIES(REP88256563:00762416-NT004447BE): 2 ms. [130+2946=3076]
(3895-1076 [3895]) CLOSE_COLLECTION(REP88256563:00762416-NT004447BE): 0 ms. [12+0=12]
(3896-1076 [3896]) DB_MODIFIED_TIME: 208 ms. [14+68=82]
(3897-1077 [3897]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3898-1077 [3898]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3899-1077 [3899]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3900-1077 [3900]) OPEN_NOTE(REP88256563:00762416-NTFFFF0010,03400000): 2 ms. [48+10464=10512]
(3901-1077 [3901]) FINDDESIGN_NOTES: 1 ms. [44+16=60]
(3902-1077 [3902]) OPEN_NOTE(REP88256563:00762416-NT00205022,00400000): 0 ms. [48+2670=2718]
(3903-1077 [3903]) FIND_BY_KEY: 1 ms. [540+38=578]
(3904-1077 [3904]) READ_ENTRIES(REP88256563:00762416-NT00205022): 1 ms. [80+400=480]
(3905-1077 [3905]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3906-1077 [3906]) OPEN_NOTE(REP8825654B:006B2EE6-NT00000316,00400000): 1 ms. [48+2142=2190]
(3907-1077 [3907]) READ_ENTRIES(REP8825654B:006B2EE6-NT00000316): 1 ms. [76+196=272]
(3908-1077 [3908]) DB_MODIFIED_TIME: 1 ms. [14+68=82]
(3909-1077 [3909]) OPEN_NOTE(REP8825654B:006B2EE6-NT00011972,00400000): 1 ms. [48+2784=2832]
(3910-1077 [3910]) READ_ENTRIES(REP8825654B:006B2EE6-NT00011972): 1 ms. [76+356=432]
(3911-1077 [3911]) OPEN_NOTE(REP88256563:00762416-NTFFFF0040,00000400): 1 ms. [48+2378=2426]
(3912-1077 [3912]) FINDDESIGN_NOTES: 1 ms. [36+16=52]
(3913-1077 [3913]) OPEN_NOTE(REP88256563:00762416-NT00000A0A,03400001): 2 ms. [48+4654=4702]
(3914-1077 [3914]) GET_COLLATION: 1 ms. [12+14=26]
(3915-1077 [3915]) READ_ENTRIES(REP88256563:00762416-NT00000A0A): 1 ms. [76+466=542]
(3916-1077 [3916]) OPEN_NOTE(REP88256563:00762416-NT00032E9A,07400002): 2 ms. [48+3152=3200]
(3917-1077 [3917]) OPEN_DB(CN=NYC/O=LV_Notes!!Corner\DocRepo.nsf): 2 ms. [134+290=424]
(3918-1077 [3918]) ISDB2_RQST: 1 ms. [14+16=30]
(3919-1077 [3919]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03000400): 2 ms. [48+5704=5752]
(3920-1077 [3920]) GET_NAMED_OBJECT_ID($PrivateDesign): 1 ms. [40+24=64]
(3921-1077 [3921]) OPEN_COLLECTION(REP88256F35:00669FD1-NT00057A5E,0000,0000): 1 ms. [42+804=846]
(3922-1077 [3922]) READ_ENTRIES(REP88256F35:00669FD1-NT00057A5E): 1 ms. [114+1762=1876]
(3923-1077 [3923]) CLOSE_COLLECTION(REP88256F35:00669FD1-NT00057A5E): 1 ms. [12+0=12]
(3924-1077 [3924]) DB_MODIFIED_TIME: 172 ms. [14+68=82]
(3925-1077 [3925]) DB_REPLINFO_GET: 1 ms. [14+32=46]
(3926-1077 [3926]) DB_REPLINFO_GET: 0 ms. [14+32=46]
(3927-1077 [3927]) DB_INFO_GET: 1 ms. [14+140=154]
(3928-1077 [3928]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03400000): 2 ms. [48+5330=5378]
(3929-1077 [3929]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03400000): 2 ms. [48+5330=5378]
(3930-1077 [3930]) OPEN_NOTE(REP88256F35:00669FD1-NTFFFF0010,03000400): 2 ms. [48+5704=5752]
(3931-1077 [3931]) OPEN_COLLECTION(REP88256F35:00669FD1-NT0000056A,0060,4000): 1 ms. [78+34=112]
(3932-1077 [3932]) FIND_BY_KEY: 17 ms. [540+26=566] (Entry not found in index)
(3933-1077 [3933]) READ_ENTRIES(REP88256F35:00669FD1-NT0000056A): 1 ms. [80+96=176]
(3934-1077 [3934]) READ_ENTRIES(REP88256F35:00669FD1-NT0000056A): 28 ms. [76+2198=2274]
(3935-1080 [3935]) CLOSE_COLLECTION(REP88256F35:00669FD1-NT0000056A): 1 ms. [12+0=12]
(3936-1080 [3936]) CLOSE_DB(REP88256F35:00669FD1): 0 ms. [14+0=14]
Subject: Same issue
We have experienced the same issue - custom applications that are suddenly slow when the users are upgraded to the 8 client.
Have you been able to determine a cause?
Subject: Application performance degraded between 6.5.4 and 8.0.2 - with debug info
Are you using a fresh install of the client without any extra plug-ins etc?
What happens if you run the Notes 8 Client in Basic mode by adding the -sa parameter to the shortcut and trying the same test?
Frunobulax
Subject: Thanks for the response…
Not an entirely clean install in that it was an upgrade but no plugins were installed.
I also tested under basic mode with the same exact result.
I didn’t develop the app so I can’t vouch for the underlying code but since I have the ND6 and 8 laptops side by side I can see that there is a significant problem here.
