AOL session problems
It appears that many of our AOL users (mostly dialup ones) are having problems logging in and staying logged in. I have come to learn that AOL uses something called Dynamic Proxy for their dialup… so the users IP address could change for every HTTP request…
We are using Multiple Servers (SSO) authentication. And yes, it appears our Domino is mildly out of date.
Can anyone shed some light on this? Any suggestions how to let these AOL users login?
Subject: AOL session problems
Damian,
I could be wrong, but I do not believe your understanding of how AOL operates is correct. Think about it – if AOL changed a user’s IP address every few seconds (or nanoseconds) while they remained online, visiting any website would be frustrating, not just your Domino hosted one.
What I know from the days when I used to use AOL to connect to the Internet is that they assigned a new IP address every time I signed on, but as far as I know, that IP address was mine for the entire session.
Though they didn’t pull this crap after I became an AOL Broadband user, AOL via dialup had a nasty habit of signing me off if they didn’t think I was an active user. It irritated me to no end because I could be on the computer actively web browsing and using the mouse, but because I was using Netscape outside of AOL, AOL thought I was inactive. The net result is that I had to repeatedly sign on again and again. That was five years ago. AOL may have eased up in recent years.
You should query your AOL users for more information. It is quite possible that they are getting kicked off AOL and manually signing back in or losing their connection and maybe AOL has new software in place that automatically re-dials in those circumstances.
In any event, you might consider using cookies to track users instead of their IP addresses.
Ken
Subject: RE: AOL session problems
Ken,
I believe I am correct. It is called AOL’s MegaProxy or something like that… every HTTP request goes out under a different IP, and HTTPS requests go out under the users actual IP.
And yes, it causes many people grief, including every major load-balancing switch manufacturer… I read discussion after discussion after discussion on this… and noone has a real solution… there are lots of bandaid type workarounds that help in some cases, like assigning all AOL proxy IPs to one realserver in your SLB config, etc. Cookie based session tracking… but they all have limitations.
We are considering changing to an active-failover server config instead of active-active… so all users go to one server instead of two… but then we need to beef up the servers… kind of sucks just to satisfy AOL dialup users…
Who knows, I thought Domino would be able to handle this anyway since we are using multiple server sessions… buti was wrong.
D
