I’d like to know if the workflow can work on the web for Room Reservation.
Has anyone used it yet? For R5, the approval for reserving the resources does not work on the web.
Subject: Reservations Not Enabled for Web
It was said that the workflow does not work in R5. It wasn’t true. It can work, however, the buttons, Accept & Decline, for the room reservations that need approval are not enabled for web because, by default, they are written in LotusScript.
It was said that the workflow worked in R6. Sure, I encountered the same problem as in R5. Is there really no way to have a web-based reservation?
