Any body can help, i will appreciate it
I am using Notes6.5 Client and i have my network database, local database and backup database, but the straange thing is when i open for instance the backup database it put me through the local database and when i click on Local one i receive the network one there some conflict on that , but i figured out that i have to right click on the bookmark (Backup Database for instance) and choose the right path to avoid conduit to other databases(Network and Local) and vis versa , is there a way how to arrange so that whatever database i choose it goes to the right path …?I will really appreciate your great help in this , thank you vary much.
Subject: Any body can help, i will appreciate it…
How did you take copies? is it replica copy or new copy ?
if it’s replica copy then it will happen like this. so you have open elements and save it.
johon…
If you are talking about replicas, you can set which replica opens by opening up the Workspace. Click on your Databases tab and the workspace icon should be the top icon in the list.
In the workspace there should be an icon for each database you have opened. If you have local replicas, there will be an arrow in the top right corner of the square. If you click this arrow you can select which replica will open.
Note that if you change locations you have to change your replica selections too, because the settings are saved on a location basis.
Also note that when you create a new replica, the icon always sets itself to the newly created replica, so if you create a local replica the icon will point to the local unless you go and change it.
Is this what you were asking? I hope this helps.
Cheers,
Beth
Subject: RE: Any body can help, i will appreciate it…
Thank you very much for your response, i will explain deferentely the matter : in my workspace i have an icon of a network DBS ,an icon of local DBS (which is the replica), an icon of a backup DBS, the pb is when i choose to open my backup DBS by clicking on the icon it opens the local Database and when i click to open Local replica database it goes to network database , what i wanted is when i open Network databae it open the network one and when i open the Local it goes to the right database as well as the backup database.Thanks for your time and any idea will be welcomed. Thank you.
