Hello!
So I tried to install Domino on Windows XP. It did work the first times but then the server got problems. I tried a new install, but then the Domino couldn’t start the Server setup.
I reinstalled Windows XP. Installation went through but no server config routine. I get the screen “Server setup loading” or something similar, and if I look at the task list I see a process named “serversetup.exe”.
I got to this forum and looked at the issue, that the reason for it,may be the graphics card, but I have it set up to 32-Bit and 800*600 pixel.
It still doesn’t work. Has anyone another idea?
bye
luis
