Allow relay to wireless connection
I purhcased a new Palm Tungston W, with built in AT&T GSM Wireless. I can read me notes mail via IMAP from my palm using the GSM AT&T Data network. The problem I have is since I have no relay on my domino R6 server enalbed. I cannot send mail from my IMAP palm session via my Domino Server. I get a “Relay Reject”. I understand this is correct and how relay blocking should work. But is there any way to allow just my Palm to relay mail via my SMTP for delivery? Since AT&T wireless assign a new IP for every session, not sure it would be possible. Would Secure sessions with authentication allow me to relay? Anyone done this ?
thanks
bill sanderson
Subject: Allow relay to wireless connection
In your server configuration document, look under Router/SMTP, Restrictions and Controls, SMTP Inbound Controls, Inbound Relay Enforcement, Exceptions for authenticated users: “Allow all authenticated users to relay”
Of course, you must be able to enter authentication info for your smtp (outgoing) server settings on the Palm.
