Agent will not run problem
Hi,I can access the database as Manager. But each time I use designer to save an agent, I got a error message: “you dont have execution access privileges for agent ‘agentName’ on ‘serverName’; it will not run.” Should I change any settings or…?
Subject: agent will not run problem
You need to check your agent execution priviliges on the server you want the agent to run on (in the server-document).
Subject: RE: agent will not run problem
sorry but I not sure where to check the settings of agent execution priviliges.
Subject: Check Agent Manager Security Settings
Sun,
Yes, check the Agent Manager settings in the server doc: Go to the Domino server doc either through the Administrator client or via the Domino Directory (names.nsf) on the server, Configuration ==> Servers ==> All Server Documents. With the server doc open, click the “Server Tasks” tab ==> Agent Manager tab.
Changes here will probably require a Domino server restart.
Ken
Hi, Thanks Ken:But I think this is a privilege problem…
