Agent Problem
I have an Formula agent in Actions menu. I want to restrict this agent to only two groups Group_A and Group_B. If anyone other that that group try to run the agent then it should give a message “You are not authorized to run this agent”. Can anyone help me with formula code on this.
Thanks in advance.
Subject: Agent Problem
In the agent properties you can set the default access for running AND viewing the agent.
