Agent not running ...'Variable not set' error msg
Hi all,
I have come across some code that a previous programmer had written to export selected documents in view. The problem I am having is that the code generates an eror message that says: “Object variable is not set” for the line that says:“carray= view.Columns”.
Can someone tell me why this is coming up? Is this a syntax thing? How can this be fixed?
Thanks,
Dan
Declarations:
Type PersonRecord
FirstName As String * 30
LastName As String * 50
Title As String * 10
Promotion As String * 50
AccountNumber As String * 50
Address As String * 30
Parish As String * 30
PostalCode As String * 10
HomePhone As String * 15
WorkPhone As String * 15
CellularPhone As String * 15
FaxNumber As String * 15
PagerNumber As String * 15
EMailAddress As String * 50
End Type
Sub Initialize
  '--Declarations
    '--Initialise Variables
Print "Initialising..."
Dim s As New notessession
Dim db As notesdatabase
Dim doc As notesdocument
Dim view As notesview
Dim coll As notesdocumentcollection
 'file stuff
Dim fileNum As Integer
Dim fileName As String
Dim rec As PersonRecord
fileNum% = Freefile()
fileName$ = "c:\DATA1.TXT"
Set db=s.CurrentDatabase
Print "Opening Views..."
Set view=db.GetView("vMailMerge")
Set coll=db.unprocesseddocuments
num=coll.count
numcols=Ubound(carray)+1
For c =Lbound(carray) To Ubound(carray)
	If c=0 Then
		columnstring=carray(c).title
	Else
		columnstring=columnstring & "%" & carray(c).title
Next
columnstring=columnstring & "#"
 'Msgbox columnstring
 ' First, open a random file with a record length equal to
’ the size of the records to be stored.
Print "Creating Text File..."
Open fileName$ For Output As fileNum%
counter% = 1
 '--loop thru
 'For i = 1 To num
Write #fileNum%, columnstring
’ Set doc=coll.GetNthDocument(i)
While Not ( doc Is Nothing )
’ Print “Getting Member…” & counter% & " of " & num
     ' If doc Is Nothing Then
         '  Write #fileNum%, notesname,"+++Person Document Not Found+++"
’ Else
           REM Msgbox pdoc.Shortname(0)
	For d =Lbound(carray) To Ubound(carray)
		If d=0 Then
			columnvals=doc.ColumnValues( d)
		Else
			columnvals=columnvals & "%" & doc.ColumnValues( d)
	Next
      'Msgbox columnvals
	columnvals=columnvals & "#"
	Write #fileNum%, columnvals
     ' End If
’ Next i
	Set doc = view.GetNextDocument( doc )
	counter% = counter% + 1
Wend
Print "Closing Text File..."
Close fileNum%              ' Close the file.
Print "Done."
Subject: Agent not running …‘Variable not set’ error msg
Check the debugger, but it looks like your view isn’t being set.
Subject: RE: Agent not running …‘Variable not set’ error msg
Thanks all (André, Matt and Robert) your expert and simple advice is greatly appreciated. The view did not exist. Thanks for pointing to that link André …I will definitely read both articles.
Best regards,
Dan
The message is explained here: Debugging Domino Applications part 1.
It is likely that your view is not getting set in this lineSet view=db.GetView(“vMailMerge”)
either because the view does not exist or the agent is running under the id of someone who does not have rights to access the view.
Try running the code through in the debugger.
