I am trying to get this agent to change the case in the InternetAddress field of the DD. We are in the process of migrating to Exchange and if the field is propercase for the domain, freetime lookup fails. I am still in the testing phase and keep hitting the dreaded ‘Type Mismatch’ error. Any review and/or correction of this would be greatly appreciated.
Sub Initialize
Dim s As NotesSession
Dim db As NotesDatabase
Dim view As NotesView
Dim doc As NotesDocument
Dim item As NotesItem
Set s = New NotesSession
Set db = s.CurrentDatabase
Set view = db.GetView("by Internet Addresses")
Set item = doc.Contains(InternetAddress)
While Not (doc Is Nothing)
Call doc.ReplaceItemValue("Domain.com", "domain.com")
Call doc.Save( True, True )
Set doc = view.GetNextDocument( doc )
Wend
Thank you so very much!!
