Agent does not pass values to a document ,was working in r5 but now it is not
Hello all:I have a huge problem
I have an agent that excutes from a hotspot button in the uidocument
the hot spot button code is:
Sub Click(Source As Button)
Dim boxType As Long, answer As Integer
If cdoc.gra_no(0) = “” Then
boxType& = MB_OK + 32
answer% = Msgbox(“The GRA No. is Obligatory,Please Enter a Value.” ,boxType&, _
	"Stop")
	Exit Sub
If Check_Uniqueness_of_GRA=1 Then Exit Sub
Dim ws As New notesUIworkspace
Dim tmpDoc As NotesDocument
Dim agent As NotesAgent
Dim v As NotesView
Set agent = cdb.GetAgent("(Fill GRA Using LSXLC)")
Set tmpDoc=cdb.CreateDocument
Call cdoc.CopyAllItems(tmpDoc)
Call tmpDoc.save (True,True)
Set v=cdb.getview("UNIDNEW")
Set uidoc=ws.currentdocument
Call uidoc.Save
If agent.RunOnServer( tmpDoc.NoteID ) = 0 Then
Msgbox(tmpDoc.NoteID)
Set tmpDoc=v.getdocumentByKey(tmpDoc.UNID(0))
If tmpDoc Is Nothing Then
Messagebox "An Error occured please contact your Notes Administrator",16, "Failure"
	Elseif tmpDoc.ErrText(0)<>"" Then
Messagebox tmpDoc.ErrText(0),16, “Failure”
Else
Set tmpuidoc=ws.EditDocument(True,tmpdoc)
Call uidoc.FieldSetText(“SaveOptions”,“0”)
Call uidoc.close
	Set cdoc=uidoc.document
If cdoc.gra_date(0) = "" Then
answer% = Msgbox(“This GRA No. does not Exist.” ,boxType&, _
“Stop”)
Else
	Messagebox "Could not retrive data",16, "Failure"
Call fill_click_field()
If Not(tmpDoc Is Nothing) Then tmpDoc.Remove(True)
so each time I run this code the agent is supposed to bring data from an as400 table and place it in the uidocument when debugging the agent the data is fine and all set but when debugging the document I find all values =“” nothing is transfered from agent to document
so if any one have any idea about this new 6 behaviour
here is the agent code just in case
thanx
Sub Initialize
Dim NSession As New NotesSession
Dim db As notesDatabase
Dim msghdr As String
Set agent = NSession.CurrentAgent
Set db = NSession.currentdatabase
Dim doc As NotesDocument
Dim sett_doc As NotesDocument
msghdr = "DB: GRA : Agent Fill GRA Using LSXLC): "
Msgbox msghdr + "Started"
Set doc = db.GetDocumentByID(agent.ParameterDocID)
Msgbox(agent.ParameterDocID)
Set sett_doc =db.GetProfileDocument("Workflow Settings")
If sett_doc Is Nothing Then
	doc.ErrText = "No Setting Document found"
	Call doc.save(True,True)
	Exit Sub
Dim x As Currency
Dim i As Integer
Dim src As LCConnection
Dim keyLst As New LCFieldList
Dim field As LCField
Dim FieldOut As New LCFieldList
Dim count As Long
Dim KeyValue As String
Dim Session As New LCSession
Dim SQLString As String
session.ClearStatus
session.ClearStatus
Set src = New LCConnection ("db2")
src.Database = sett_doc.data_source(0)
src.Userid = sett_doc.txt_user_name(0)
src.Password = sett_doc.txt_pass(0)
Call src.SetPropertyBoolean(4,True) 	src.Connect
KeyValue = doc.gra_no(0)
Set field = keyLst.Append("LLOT", LCTYPE_TEXT)
field.Value = KeyValue
SQLString = "Select  LLOT,LPROD,LRDT,LMSC,LNMFGR,IUMS,IITYP,LRCPT,LNMLOT,LNCNTR,IDESC  from "+ sett_doc.txt_table(0) +_
" INNER JOIN "+sett_doc.DescTable(0)+" ON "+sett_doc.txt_table(0)+".LPROD = "+sett_doc.DescTable(0)+".IPROD"+_
" where LLOT = '"+ KeyValue +"' and (LMRB = 'H' or  LMRB = 'Q')   and (IITYP = 'R' or IITYP = 'P' or IITYP = 'B') "
Msgbox(1)
count =src.Execute(SQLString,FieldOut) 'Execute the Query
Dim strDate As String
count = src.Fetch(FieldOut)
If count<1 Then Exit Sub
If count> 0 Then
doc.gra_no=Cstr(FieldOut.LLot(0))	strDate=Mid(Cstr(FieldOut.LRDT(0)),7)+"/"+Mid(Cstr(FieldOut.LRDT(0)),5,2)+"/"+Left(Cstr(FieldOut.LRDT(0)),4)
	doc.gra_date = strDate		doc.pur_order_no=Cstr(FieldOut.LMSC(0))	doc.unit=Cstr(FieldOut.IUMS(0))		doc.ITYPE = Cstr(fieldout.IITYP(0))
doc.qty_rec=FieldOut.LRCPT(0)		doc.lot_no=Cstr(FieldOut.LNMLOT(0))	doc.item_desc=Cstr(FieldOut.IDESC(0))	Call doc.save(True,True)
Else
doc.ErrText=Cstr(KeyValue)+ " is not a Member"
	src.DisConnect
End
Subject: agent does not pass values to a document ,was working in r5 but now it is not
I believe you are missing a delete, and still looking at a cached document. Compare your agent to the sample agent I published in the article about RunOnServer method, you will see an example.
Direct link in the article is in the Agent FAQ.
