Agent, Call doc.Save(False, False, True) (Unread marks) and Agent Signer
I have an agent which moves documents to the Junk folder based on a field in the document.
If sread = 1 Then
Call doc.PutInFolder(“($JunkMail)”, True)
Call doc.RemoveFromFolder(“($Inbox)”)
The idea is that the mail should be marked as read when moved to the folder. This is working if I (the owner) am the signer of the agent. If the server has the agent it is not working.
I guess this happens as unread marks are personal and stored in the desktop.ndk!?
Is there a way I can avoid this - mails will always be marked as read nomatter who has signed the agent?
Thanks.
Kjeld
Subject: Agent, Call doc.Save(False, False, True) (Unread marks) and Agent Signer
you are correct, unread marks are user (ID) specific.
Subject: RE: Agent, Call doc.Save(False, False, True) (Unread marks) and Agent Signer
And a possible workaround??
no workaround but why do you care if they are read or unread if you’re putting them in the junkmail folder?
I dont care. But my users do…They dont wanna have the junk mail included in the unread count on the workspace. I see the point/request but as well as a thing which isnt that important.
Would just be nice.
:slight_smile:
Cheers.
Kjeld
