Agent authorisation problem (LEI)
I have the following problem, we have LEI running on a domino server name = server 1,
LEI is starting an agent on server 3 that agent will set readers field in documents on server 3.
The agent is signed with server ID form server 2 (server 2 and 3 are in a cluster).
The user that is running the agent is server 1
when I run the agent on server 3 I get the error “Function Initialize: 4005 on line: 91 with message: Notes error: You are
not authorized to use the server (LookupTech)
This is when I try to get documents by a view, or when I try to count the entry’s in the view, The database and the views are
filled.
I have looked at the authorisation of the views (the box all readers and above is checked).
The server 1, 2 en 3 are manager in the ACL on server 2 and 3.
We are running Notes 7 on the server.
I tried different views but the problem still exists
Subject: Agent authorisation problem (LEI)
Make sure Server 1(LEI) is listed as a trusted server on the Server Config docs for 2 & 3.
Subject: RE: Agent authorisation problem (LEI)
Hello Rami,
Thanks for your response we changed the server documents and the problem is gone.
Gertjan den Hartog
