Hello all,I’m posting this again as it seems that no-one seemed to have any suggestions last time.
Small problem with a users personal address book…
When selecting a letter from the index down the left hand side to ‘goto’ that letter, it will jump to the bottom of the address book. Does not do it for all letters only a few, i.e. G, P,Q, and R.
I have created a new personal address book and pasted in the address and it does the same thing. Deleting some of the address from the letter will do a temp fix until you re-add the addresses. i.e. delete the first three entries from G and then you can jump to it until you manually re-add them again.
I have tried freshing index’s etc.
Help me please. Any ideas anyone?
Subject: Address book index problem
My manually re-adding them do you mean paste it back?
If you do, try by creating new address manually.
Have your contacts been imported or migrated from somewhere?
Subject: RE: Address book index problem
Thank you for your response.
Re-adding the entries is by creating new entries manually and not by pasting them in.
Contacts were all added manually, not imports.
Go figure!
Hello,
Did you ever find a solution to this? I have 1 user with the same problem. It only affects letters H and R?? Weird. It selects the document in the address book correctly, but the view jumps to the bottom.
Cheers
Lee
Found a solution. I created the full text index on the address book and all is now good.
Exported all entries to Structured text format. Created new address book and then imported the exported files.
